Eagle Lights LED's
Old May 2, 2024 | 11:31 AM
Topper Harley's Avatar
Topper Harley
Stage I
Default Eagle Lights LED's
Has anyone installed Eagle Lights LED's and Passing lights? I have everything working, my question/problem is previously on OEM lights With high beam or low beam on, it didn't matter, my passing lights stayed on. Now, with high beam on everything is on and when I switch to low the passing lights turn off. CS at Eagle was blah.... They said my bike is programmable to keep them on (the passing lights) at all times. Can anyone direct me how to do this? I would like the passing lights to stay on at all times. Thanks.
2020 FLHR
Old May 2, 2024 | 01:17 PM
HD_noobie's Avatar
HD_noobie
I had it done at the dealer, didn't charge me anything, took 10 min.
Old May 2, 2024 | 08:47 PM
btsom's Avatar
btsom
I have the Phase 3 Eagle lights headlight and passing light set. Wish the high beam on the headlight was a bit brighter but the passing lights are excellent. All of mine worked on the first try after installing so I don't know if any of the lights might be polarization sensitive. Haven't a clue why your passing lights were on all the time with the old halogens but not now. Now they work in reverse to the normal factory setting. Without being reprogrammed, the passing lights should be on when the headlight is in low beam and turn off when high beam is selected. Hopefully that won't be too expensive to fix. I can only GUESS that polarity might be reversed in low beam for some mysterious reason.
Old May 3, 2024 | 07:41 PM
NorthWestern's Avatar
NorthWestern
2020 FLHR
I just bought the Harley Passing light setup for my FLHXS, and bought the Eagle LEDs to go in them.
You can get the programming done at the dealer, I luckily have the Techno Research tool to do this.
I am a fan of the 2nd gen Eagle lights, I have bought them before, so I am sure they will serve me well as they have in the past.
I am going to try to get them installed next week.
Dr. Tiki
Sep 7, 2021 06:27 AM
Panchorelly
Aug 27, 2014 10:43 PM
tasman117
Sep 14, 2013 05:22 PM
TedMan
Mar 20, 2013 03:23 AM
larrysroad
Oct 9, 2006 12:13 PM
