Should be a nice running combination. If youre doing it yourself I would coat the inside of the inner cam bearing with grease. Ive changed numerous twin cams with no issues, but I read about M8 bearings breaking when removing. So I coated mine and when I was removing it I heard a pop, I stopped, loosened and made sure the tool was in all the way. When it came out it had broken, but the grease kept everything together.
i also changed out my lifter cuffs, if doing it again I would have just kept the stock. My bolts came out with no issues, but some have not had good luck with those lifter cuff bolts.
