Touch screen issues
Old Mar 4, 2025 | 11:44 AM
Loach's Avatar
Loach
Stage III
Default Touch screen issues
I have a 2023 RG Limited. The touch screen changes on its own sometimes. The cruise control shut off on its own, and the neutral indicator flashed on and off a few times. Any one else have similar issues?
Old Mar 4, 2025 | 12:56 PM
Keithhu's Avatar
Keithhu
Welcome to HDForums. Is it still under warranty?
Old Mar 4, 2025 | 01:17 PM
Loach's Avatar
Loach
Stage III
Yes
Old Mar 4, 2025 | 02:16 PM
Keithhu's Avatar
Keithhu
Before you start fiddling around, if it's still under warranty, it's their problem, that would be my advice.
Old Mar 4, 2025 | 02:38 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Welcome to the HDFORUM. Hopefully, just a connection issue. I would let the dealership take care of it.
Old Mar 5, 2025 | 08:47 AM
Loach's Avatar
Loach
Stage III
That's the plan.
Old Mar 6, 2025 | 05:37 AM
Kuz's Avatar
Kuz
Probably just needs a re flash.
Old Mar 13, 2025 | 08:10 PM
23StreetGlideSpecial's Avatar
Check battery cables if you want. Make sure they are tight. Anything more have the dealership deal with it. This way if you have issues down the road when warranty is gone it may still be covered.
Old Mar 16, 2025 | 04:20 PM
VortecCPI's Avatar
VortecCPI
Do you have latest software installed? If not you should do so. These new bikes are know for having automation issues.
Check HD SIP for latest updates...
Old Mar 17, 2025 | 10:04 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Active Streak: 30 Days
Battery or connections
Maybe pull main fuse to reset
Any codes?
Take to dealership since under warranty and ask them to check it out.
It should be something simple. I have a 21 and a 22 which are the same as your 23 and have never experienced these issues.
