FOB Battery Replacement
Old Mar 5, 2025 | 07:07 AM
702's Avatar
702
Default FOB Battery Replacement
How long has your battery lasted? How often do you change it? Do you wait till is dies or do you periodically change it?
Old Mar 5, 2025 | 09:03 AM
btsom's Avatar
btsom
Many people replace the batteries annually, others keep a spare battery in their saddle bag or other storage location. Personally, I despise the security system and if there is ever a chance to have the bike put in the service mode, without having an additional 1/2 shop hour added to the bill, I will do it. While 99% of security problems are OWNER factor, dead FOB battery, FAILURE to set a PIN and learn how to use it, antenna lead broken from the module during maintenance, the reality is that if a pro wants your bike, he will get it. The ignition/fork lock will deter casual joy riders.
Since you are stuck with it, choose one of the above options AND set your PIN and learn how to use it.
Old Mar 5, 2025 | 09:09 AM
Uncle Larry's Avatar
Uncle Larry
Every year ... Just because
Old Mar 5, 2025 | 09:10 AM
702's Avatar
702
I've been changing them every 2 years, and was just curious to see if perhaps I was over/under doing it.
If you ever ride through Vegas, I'll turn off your security for you.
Old Mar 5, 2025 | 11:06 AM
470004's Avatar
470004
I change my annually and keep a spare in the saddlebag. The spare one is also changed out annually when I change the ones in the FOB.
Old Mar 5, 2025 | 11:22 AM
cobra23's Avatar
cobra23
Batteries are cheap. Spend a dollar once a year and avoid aggravation down the road
Old Mar 5, 2025 | 11:27 AM
jdunn01's Avatar
jdunn01
I put the PIN and PIN Reset procedure into Notes on my iPhone incase i ever need it.
Old Mar 5, 2025 | 11:56 AM
ksol5's Avatar
ksol5
Every spring I change mine, and my wife's, and buy brand new spare batteries to store in the saddlebags. Security pins come up quite often on this forum, as others have said, make sure you set yours, and know how to use it if you need to!
Old Mar 5, 2025 | 05:23 PM
pyuchem's Avatar
pyuchem
Every year…just to be safe.
Old Mar 5, 2025 | 05:30 PM
RollaMo's Avatar
RollaMo
I have a 2015 Ultra Limited. I have replaced the FOB battery twice since I purchased the bike new in 2015.
Have never once had any kind of FOB or security issue.
But if the FOB battery was to ever die on me while out riding, I know exactly what my PIN is and how to use it.
I have also used the PIN a few times even though I didn't really need too, just to make sure the process works.
