Sticking Throttle
Old Mar 10, 2025 | 12:38 PM
bigmoe7178's Avatar
bigmoe7178
Stage II
Default Sticking Throttle
ello I have a 2014 Electra Glide Limited with heated grips. The bike has throttle by wire. All of a sudden the throttle is staying open. Any idea how to fix this?
Old Mar 10, 2025 | 01:06 PM
Goose_NC's Avatar
Goose_NC
Meaning it will not return on it's own? Or will not close manually at all?
Old Mar 10, 2025 | 01:08 PM
bigmoe7178's Avatar
bigmoe7178
Stage II
It will not return on its own. I have to force it closed
Old Mar 10, 2025 | 04:32 PM
GalvTexGuy's Avatar
GalvTexGuy
Loosen the switch pack screws and adjust its position until throttle grip moves freely.
Old Mar 10, 2025 | 07:44 PM
btsom's Avatar
btsom
To clarify the above, the most common cause is the twist grip being "pulled" inboard by the switch pack so it binds on the end of the handle bar. Loosening the switch pack and moving it outboard slightly (away from the center of the handlebars) relieves the binding and all should be normal again. Was there a heavy bump against the twist grip pushing it inboard, or did the bike fall over and the twist grip get jammed into the floor or ground? Something like that has enough force to move the switch pack inboard enough to cause the binding you are experiencing.
If that doesn't fix it, you may have a lot of dirt between the twist grip and the handlebar that needs to be cleaned out. I hope your heated grips didn't have a thermal "runaway" that might have softened and deformed the plastic tube making the inner surface of the twist grip.
Old Mar 10, 2025 | 11:48 PM
Taxgod4u's Avatar
Taxgod4u
Can heated grips actually have a "Chopper Chernobyl"?
Old Mar 13, 2025 | 07:07 AM
havinabubble's Avatar
havinabubble
just fixed similar on a friends Road King... turned out when someone fitted his bars they had rotated the TBW further than they should (about 360d)
I undid the switch gear, pulled the throttle by wire out and let the wire rotation undo, now it doesn't 'spring' open when he lets go. It was causing a higher than normal idle.
YMMV
casarva
2014-2024 Touring Models
Nov 28, 2022 02:47 PM
onedae
Jun 25, 2014 11:48 PM
ayates1415
Jun 5, 2011 04:18 PM
nmfxstc
Apr 25, 2008 10:53 AM
btefft
Aug 6, 2007 08:51 AM
