Lowering kit
Old Apr 26, 2025 | 03:26 PM
dragger's Avatar
dragger
Default Lowering kit
Hello,
15 days ago I installed Bitubo 13" rear shocks and Wilber springs on my FLHXS 22. I am very happy with Bitubo and their softness, which I cannot say about the Wilbers which are a little too stiff for me. I will see if it is a good combination in the coming months. However, what bothers me is that the Bitubo are 8 mm (1/3") higher and the Wilbers are 6 mm (1/4") lower, which means that the front end is about 14mm (ł⁵/₆₄) lower, which is still noticeable when riding. I would also add that the Road Sofa seat raised me about 3/4". Everything was adjusted and measured with the stock rider compared to the installed one. I'm thinking about installing a kit to lower the rear end by max 1" but they should be made of high-strength iron, not aluminum, and they should follow the angle of the original shock absorber. I read somewhere that La Chopper has these on offer. I sent an inquiry but they haven't responded. I'm interested in your opinions and suggestions.
Thanks and regards
Old Apr 27, 2025 | 10:43 AM
Jersey Drew's Avatar
Jersey Drew
Originally Posted by dragger
Hello,
Thanks and regards
i do not like lowering kits. They are ok for a bar hopper but not for a touring bike. It changes the angle of the shock and therefore negates any benefit of the longer stroke of the 13” shock. At that point just swap the system out for a shorter shock/spring combo. Although you will not have the benefit of the longer stroke it will be tuned for the shorter travel and therefore give you a better ride compliance than that of a longer shock with a lowering kit.
i have the legends 13” on my glide and get the full benefit of the longer stroke without much change in ride height. When tuned properly they are barely 1/4 in taller at rest with rider weight on them. But you get the full extra inch of travel when hitting bumps.
you shouldn’t measure the bike unloaded because that doesn’t matter. You have to look at how the bike sits at full weight of rider and/or passenger.
Old Apr 27, 2025 | 01:28 PM
dragger's Avatar
dragger
Hello,
Jersey Drew I completely agree with you. I think nothing would be lost if the rear end lowering kit was designed to have the same angle as the original shock absorber.
Thanks and regards
Old Apr 27, 2025 | 03:21 PM
Jersey Drew
Hello,
Thanks and regards
good luck! i have installed a few on my friend's bikes and they work and do not bind. so you will not have any issues with that.
Old Apr 28, 2025 | 06:28 AM
dragger's Avatar
dragger
Can I ask you to tell me which model you installed and where you bought them. If you happen to have any pictures of them installed. Many thanks.
Old Apr 28, 2025 | 09:43 AM
Jersey Drew
i do not. my buddies purchased on their own and i just turned the wrenches. but i can say it was probably not the most expensive. they never complained and the kits held up as expected. i just know that suspension geometry is funny so i wouldn't do it personally.
Old Apr 28, 2025 | 03:42 PM
Taxgod4u's Avatar
Taxgod4u
these wont change the shock arch as they are a straight drop of the lower shock bolt hole, but you should cinch up your forks to fix the rake.
Old Apr 29, 2025 | 01:49 PM
dragger's Avatar
dragger
This is a Rear Lowering Kit for 2002-2016 Harley-Davidson Touring Motorcycles. Mine is a 2022 model. I don't know if they will fit. I sent an inquiry to La Chopper but they don't fit me.
Old Apr 29, 2025 | 01:56 PM
smitty901's Avatar
smitty901
The Advant Black lower kit works just fine. I was won over.
https://www.advanblack.com/2-inch-lo...2002-2022.html
Old Apr 29, 2025 | 02:25 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Hello,
Thanks and regards
Here is a LINK to some Lowering Blocks.
Thousands have used them on Touring models for millions of trouble free miles.
They will lower your bike 1" at the rear axle. Since there is a bit more leverage on the shocks, your Bitubo's will ride even better, and you may bump up your pre-load just a tad (about half a turn), you can also adjust your damping, if needed, with the 5 position lever.
The physics of the design make the 6061 aluminum. The only steel ones I have seen are welded and the physics of the design have yielded failures occasionally.
Kevin
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
