XM Radio kit problems
Old May 15, 2014 | 08:05 AM
DAKSY's Avatar
DAKSY
Originally Posted by 08 Bagger
I have the 3 month trial subscription which includes all channels along with what Harley calls Specialty Services (weather, traffic, radar and fuel prices).
My satellite service was working great for a couple weeks but last weekend while on a ride and again today while the bike was in the garage with the radio on, even with 3 bars showing on the signal strength meter, the audio on XM would slowly fade out to a crackling sound and silence. While on the ride, I turned the radio off for a minute and then it worked fine the rest of the ride. Today, even though I turned the radio off, it took at least 5 minutes before the XM started playing again.
Anyone else experience this? I pulled the batwing off to check the antenna connection but everything looked fine. Maybe a bad XM module? If so, this should be fun trying to explain this to the dealer when its so intermittent.
Yeah. Mine started acting up last week on my way to work. The station I was listening to got staticky & totally faded out. I thought it might just be one station, but none of the other programmed stations worked. I was in the "city" (if Troy, NY can be considered one!) surrounded by 3 story buildings & thought that could also be a cause, but it hadn't happened in that spot before. I tuned to FM & no issues. About a mile later I re-tried the Sirius & it was STILL out. After work I fired it up & switched over to Sirius & all went well until last night. I was out on a country road with no really tall trees & it crackled & faded out again. Rode about 2 miles & it was back. Worked fine this AM. I will call the dealer tomorrow to schedule an appointment to have it diagnosed next week. Taking the GF to Italy for 10 days, & I'll let the techs play with it...
Old May 15, 2014 | 11:34 AM
GeneseeGap's Avatar
GeneseeGap
I was in my suv driving in the panhandle of Texas around that time last week and it was out for several minutes at several different times. Strange as I have never lost an xm signal unless im in a tunnel so it may have been some type of astro science thing.
Italy! Enjoy!
Old May 15, 2014 | 01:43 PM
scottt's Avatar
scottt
Remember; its Satellite radio. Their can be times that you are in the wrong spot for the satellites. On the other hand, it could be aliens messing with us?
I have had the same issue with my car, that is why I think it has to do with satellites.
Old May 15, 2014 | 02:49 PM
01XLH's Avatar
01XLH
I've had XM since they started broadcasting. I only use one "radio" at home, at work, in the cage and on the Glide, so I'm not real sure about the HD "XM Module".
As far as reception of their signals FYI,
XM broadcasts from Geostationary satellites, they sit in one place over the equator, unless something has changed, Sirius using satelllites that circle the Earth, twice a day. And IIRC both (I know XM does) also use ground base repeater stations.
When at work I get the satellite signal, and on the bike and cage I get both depending on my location. Around tall buildings I get the ground based 90% of the time.
When I got a new receiver a few months ago (it was free, why not?), I set-up to have it activated and an hour later nothing, I called, asked for a refresh and had it in about 2 minutes. YMMV
Well wear your foil hat like the rest of us!
And at least we don't have to use these antennas
And a Wille G autographed poster from the XM 60's on 6 studio.
Attached Thumbnails XM Radio kit problems-xm_ant.jpg   XM Radio kit problems-wille_g_d.jpg
Old May 15, 2014 | 07:13 PM
YPD485's Avatar
YPD485
My dealer who ordered me another XM Module said that the modules are on backorder till end of June. He said the motor company knows they have a problem with the module. No doubt they are making a revision so it operates correctly.
Old Jul 11, 2014 | 03:50 PM
iBleedOrange's Avatar
iBleedOrange
Stage IV
Originally Posted by Tony Steele
My issue with the kit on my limited is that I lose my preset xm stations, the regular fm will stay but the xm channels are replaced with Weather band stations.
Tony Steele, you mentioned that you had some trouble with loosing your XM presets, were you able to resolve that problem? If so, how?
Thanks,
Michael
Old Jul 11, 2014 | 08:44 PM
Tony Steele's Avatar
Tony Steele
Thanks,
Michael
Nope, lost them just this morning. The dealer tells me Harley told them the issue will be addressed in the next update. Whenever that happens, I've been waiting months. I haven't had time to fight about it anymore recently.
Old Jul 12, 2014 | 03:24 PM
iBleedOrange
Stage IV
Thanks Tony, I've had it happen a couple times but I thought it was something I was causing...
Old Jul 13, 2014 | 12:49 PM
BJI's Avatar
BJI
I had XM installed by my dealer before delivery. I rode home and tried several times without success to activate the service. Made three calls to XM -ugh. I rode back to the dealer and, like magic, it completed activation just as I rolled into the parking lot. Yes, activation can be described as anything but smooth. Bigger problem for me is horrible reception - keep seeing "Signal Lost." I feel it is a poor antenna design plus it sits in a difficult location for decent reception. The money for the module plus labor is spent - no getting that back now. I probably will not pay for service beyond the three free months. I'm having better luck with Bluetooth streaming from my phone for commercial-free music...
Old Jul 13, 2014 | 02:15 PM
01XLH's Avatar
01XLH
I'm talking XM, not Siruis, I've been with XM since it started and do not know a thing about Sirius except they use different satellites in a different configuration.
The antenna design has been very good for a number of years already. Based on where it's supposed to be mounted under the fairing, that could be a problem depending on where and what direction you're headed.
Also, cities across the country have terrestrial repeaters and it's surprising how often you may get it from a local repeater rather than the XM Satellites. The radio decides which signal is better and switches as needed.
While you have a clear view of the South/Southwest and still lose signal, I would suggest making sure the antenna connection on the XM unit is good and the cable itself is in good shape. The cable to/from the antenna provides DC power to the antenna as well as the received signal to the XM unit.
Good Luck
