daymaker headlight install
Old Mar 31, 2014 | 10:38 PM
bigh8840's Avatar
bigh8840
Follow the stock harness back to a little black box which is connected to the frame, that separates and it slides off the frame.. That is where your adapter harness plugs in at.. The stock harness with two plugs is sitting in the box next to my old headlight, sorry I'm not home (away on business) or I would take a pic..
... Just follow the two stock plug wires back to that little black plug (should resemble the opposite end of the new harness) and with a little pressure it'll come apart..
Hope that helps
Old Mar 31, 2014 | 10:43 PM
Dave Thorpe's Avatar
Dave Thorpe
From the Harley site:
Old Mar 31, 2014 | 11:00 PM
steveg56's Avatar
steveg56
Talking
Sorry guys I got it! I did not follow back to the frame where the two become one. I unplugged there and plugged in the new harness and all good to go now.
Thanks for all the suggestions. While you guys were writing here I took the headlight off again to see if I missed something and sure enough I didn't know there was a jumper cable that need to come off.
Thanks again...you all were right simple install! :-)
Old Apr 2, 2014 | 01:53 PM
lazye's Avatar
lazye
I'm about to order the Black Daymaker LED #67700040A, Wiring Harness #692000897, and I think I will also need the Black Trim Ring #46555-03B.
Has anyone used this setup?
Old Apr 2, 2014 | 02:33 PM
DBLXX's Avatar
DBLXX
Stock bulb has 2 plug-ins. Unplug them. Now you are left with a harness that has one plug going into the bike and 2 ends dangling, right?
Plug the new harness into the bike and now you are left with 1 plug into the bike and 1 plug left for the LED headlight.
Done.
Old Apr 2, 2014 | 02:34 PM
DBLXX's Avatar
DBLXX
The OLD harness must be taken off and replaced with the new harness. I think that is the piece of the puzzle missing.
After the install you will he left with the OEM harness and the OEM headlight. Pack it up and put it in the attic
Old Apr 2, 2014 | 02:39 PM
billatstarbrite's Avatar
billatstarbrite
I had the dealer do the DayMaker upgrade while I was out of town on along business trip, so no feedback on that side. However, I can and will say the DayMaker light is freaking amazing. The way it lights up the road has to be seen to be truly appreciated. Do it.
Old Apr 3, 2014 | 12:28 AM
steveg56's Avatar
steveg56
See post #13
Old Apr 8, 2015 | 08:37 AM
wataugahd's Avatar
wataugahd
Stage II
You have right plug just didn't go back far enough on bike harness to replace with new harness. The short piece with 2 plugs unplugs then put in new harness
Old Apr 8, 2015 | 03:45 PM
mparrish2010's Avatar
mparrish2010
I bought the HD black extended trim ring for my 14 SG after I installed the LED daymaker and I'm not happy with the gap it leaves at the bottom where the two parts of the ring meet. You think Harley could have done better than they did.
