Automatic Volume Control
Old Apr 14, 2014 | 03:08 PM
MrC's Avatar
MrC
Question Automatic Volume Control
On my 2014 Ultra Limited I'm trying to get the Automatic Volume Control to work. I can get to the setting directly under the Balance and Fade option and can set it to 1 - 4. But, nothing happens. I thought when you came to a stop the volume should decrease to whatever the 1 - 4 settings is set to.
The volume stays at where ever I had it set to, which is normally loud on the radio, media, or weather selection! Am I missing another setting somewhere?
Old Apr 14, 2014 | 03:15 PM
14GuineaPig's Avatar
14GuineaPig
The AVC does not work correctly on the 14 models. When you set it at number 4 it barely adjusts the volume and the only time I hear a change is when I pull away from a stop or when I am just about stopped.
Old Apr 14, 2014 | 03:17 PM
MrC's Avatar
MrC
AHH, so we're supposed to figure that out! Harley Dealers at not in the know about this!
Old Apr 14, 2014 | 03:18 PM
jkane13's Avatar
jkane13
Not missing anything. There are other threads on this. It kind of works, but not significantly. It only changes once when you go from 0 to something and then when you hit 0 again. The 4 options are how much it increases all at once. No more changes at different speeds. Not very useful.
Old Apr 14, 2014 | 03:31 PM
01XLH's Avatar
01XLH
Phew, I thought it was just me.
I waited until the end of February to buy, thinking H-D would have the minor bugs worked out by then.
I'm liking this 6 week old 14 Ultra less and less.
Old Apr 14, 2014 | 03:38 PM
Harttoo's Avatar
Harttoo
Set the avc to 4 and it will work sometimes.Hope the next update makes it a little better.
Old Apr 14, 2014 | 03:41 PM
Shep68's Avatar
Shep68
Guess I'm lucky. My radio gets noticeably muted when coming to a stop. Think mine is set on 4 but the kid at the dealer did it so not sure. Have to check tonight.
Old Apr 14, 2014 | 03:44 PM
scarey's Avatar
scarey
Mine does turn down after stopping & increases back to where I had it set after taking off - I'm lucky I guess?
Old Apr 14, 2014 | 03:49 PM
dpmerrill's Avatar
dpmerrill
Try a lower setting. Mine is set to one bar, and when I stop it turns the volume down almost too much.
Now I'm thinking of trying a higher setting. Maybe the settings work backwards from the way I thought they would...
Old Apr 14, 2014 | 04:13 PM
GSHOG's Avatar
GSHOG
On my '14 Limited the AVC did not work at all prior to the latest software update and now it works sometimes. When it does work it is very slow to adjust, either up or down, and none of the settings (1-4) on the setup menu make any difference at all.
I am not a software programmer but have worked around aircraft avionics systems for 30+ years and this seems to me like it should be a pretty simple change. Maybe next time...
