Garmin base camp route
Old Apr 17, 2014 | 12:59 PM
UppercaseJC's Avatar
UppercaseJC
Default Garmin base camp route
I have finally figured out how to import a route from HOG Ride planner to my boom box but would like to import a route using Garmin Base camp. Can anyone help me in doing this? I have tried several ways but so far no luck. Very frustrating. Thanks
Old Apr 17, 2014 | 05:50 PM
ChristoHD's Avatar
ChristoHD
Question
Sure, I will try and help.
You have created the ride in BC, or you have created the ride in HD RP?
Old Apr 17, 2014 | 06:38 PM
UppercaseJC
I have created the ride in Garmin Base camp and now want to load it into the Harley Boombox 6.5.
Old Apr 17, 2014 | 06:39 PM
ChristoHD's Avatar
ChristoHD
You on Mac or PC?
Old Apr 17, 2014 | 06:53 PM
ChristoHD's Avatar
ChristoHD
Originally Posted by ChristoHD
You on Mac or PC?
Ok - ignore that last question - BC is Mac only - DUH on my part.
Easy enough - so you have a "list" created on BC with all the routes and waypoints etc. Correct?
Select that list - then go up to "file" in the menu, scroll to select Export "your list name"
It prompts you where and what format - choose your desktop (where), and select the .GPX 1.1 file version (little pop up menu on dialogue box for save).
There it is on your desktop - now copy that to your USB stick or flash drive, take it to your bike and import JUST the routes.
Old Apr 17, 2014 | 07:32 PM
ChristoHD's Avatar
ChristoHD
One thing to keep in mind - when using Basecamp with a Garmin - when you use waypoints you can select them on your route and tell BC/Garmin GPS to not notify you of these points upon arrival, that they are "shaping points". So the Garmin GPS uses them ONLY as route shapers - BUT when you load these routes onto the HD GPS 6.5 system, it sees them as Via Points and you will have to pass over/through them, otherwise the HD system will keep recalculating for you to it.
As another member posted in another thread - drill down when creating waypoints - make SURE they are on the road and side you will be traveling, avoid putting them on intersections, wrong side of the road in the opposite direction of travel you are going, and most common is you have two roads right next to each other and you are driving on one road and you are supposed to be on the other.
I go through my routes at super mag - all up close and personal like - to make 100% sure I didn't place those wp's incorrectly. And as often as I use it, I still find a few little boo boo's. :-)
Old Apr 18, 2014 | 10:45 AM
dwludwi's Avatar
dwludwi
FYI, Basecamp is available for the PC as well. I have been running it on a pc for several years.
Old Apr 18, 2014 | 11:11 AM
ChristoHD's Avatar
ChristoHD
Thumbs up
Ah - ok - my bad AGAIN! LOL Tried to find a reference for PC on the Goog, couldn't find in my quick search - now I know, Thanks!
Old Apr 18, 2014 | 05:42 PM
UppercaseJC
Got it as always this group is great. Thanks for the help
john2112
Sep 8, 2018 07:17 PM
alandchris
Apr 28, 2016 02:11 PM
smithmx47
Aug 26, 2014 09:09 AM
Twisty Seeker
Audio Systems
May 5, 2014 10:44 PM
springerchop
Apr 6, 2008 11:35 AM
