110 ci upgrade
Old May 9, 2014 | 11:53 AM
Pastor Ron's Avatar
Pastor Ron
Default 110 ci upgrade
Has anyone installed the 103 to 110 upgrade on the Rushmore yet?
Old May 9, 2014 | 12:03 PM
JC0311's Avatar
JC0311
Goldcon did if I'm not mistaken. But he also did a stage 4 on it too. I'm sure he'll check in and fill in details. I'm doing a stage 4 on my 103 in a couple weeks, it supposed to net you more power and torque than a 110 upgrade.
Old May 9, 2014 | 01:32 PM
scottt's Avatar
scottt
I have heard nothing but positive about the 103 stage 4 upgrade. IMO, better than going 110inches.
Old May 9, 2014 | 03:40 PM
Smiff's Avatar
Smiff
I can find very much info on the stage 4 . Roughly what does that mod cost?
Old May 9, 2014 | 08:00 PM
Goldcon's Avatar
Goldcon
I did the 110 stage 4 upgrade to the 103 as JC mentioned above. The reason I stayed with the 110 instead of the 113 was I wanted to keep my warranty on the new bike (and yes this can be done).The mechanic that built mine said it really wasn't worth the money to go to the 110 unless I put in the .10 over high compression pistons and re bore the cylinders and cases for the larger pistons to get a nice tight fit, rather than the slop that comes in the 110 kit. Just had my 1000 mile service and Dyno tune yesterday. The results- 115 horsepower and 112 torque. I must add that the difference before and after the Dyno tune are unbelievable. I could of gotten higher numbers with different heads but I wanted to keep my warranty besides it is way fast enough with the proper tuning!! I also swapped out the cams that came with the 110 kit for 260's which put the power right where I wanted it 3rd and 4 gear.
Old May 9, 2014 | 08:05 PM
Goldcon's Avatar
Goldcon
To do it right your probably looking at 5 grand, give or take.
StreetGlider321
Engine Mechanical Topics
Feb 7, 2015 09:47 PM
jeff.georgalas
Exhaust System Topics
Oct 9, 2011 10:07 PM
jackinthebox
Jun 21, 2009 08:49 AM
Silverearl
Jun 7, 2007 12:37 PM
silvrbill
Jun 4, 2007 04:30 PM
