Drilling inner fairing
Old Jun 21, 2014 | 11:51 AM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
Default Drilling inner fairing
I need to drill a 7/8 hole in my inner fairing? I've drilled small holes in the inner fairing of my previous bikes but nothing this big. The only bit i have that's big enough is a spade bit. How will this work on the type material the inner fairing is made of, will it cut through smoothly or get too hot and melt through, making a messy and uneven hole? I hate to go out and buy a 7/8 drill bit but I would if that's what it takes to drill a smooth even hole.
Old Jun 21, 2014 | 12:05 PM
p51bombay's Avatar
p51bombay
Spade will be messy, get a Unibit
Old Jun 21, 2014 | 12:13 PM
cynjon's Avatar
cynjon
I would expect a spade bit to result in "blow out" on the back of the fairing, especially in thin material. I wouldn't risk it. Even a standard bit may chip or blow out a bit on the back. For thin materials like a fiberglass fairing, nothing beats a step drill bit (or uni-bit) such as this set from Harbor Freight.
I have a set and they work great--I use them all the time. A great investment in my opinion.
EDIT:
What he said...
Old Jun 21, 2014 | 12:29 PM
dontdropit's Avatar
dontdropit
Looks like that's what i need. Thanks
Old Jun 21, 2014 | 03:32 PM
GlidingJoe's Avatar
GlidingJoe
Do share, what are you installing???
Old Jun 21, 2014 | 03:34 PM
Gunnysgt's Avatar
Gunnysgt
Use a regular bit and put masking tape over the plastic before you drill.
Old Jun 21, 2014 | 06:52 PM
dontdropit's Avatar
dontdropit
A USB port from 3br Powersports. I will use it to power my GPS and or my phone.
Old Jun 21, 2014 | 08:29 PM
p51bombay's Avatar
p51bombay
Why not get a USB adapter for the power port that's already there?
Old Jun 21, 2014 | 08:38 PM
buzdean's Avatar
buzdean
uni bit or a hole saw would work--masking tape is a good idea
Old Jun 21, 2014 | 08:55 PM
dontdropit's Avatar
dontdropit
My experience with that isn't very good. The adapters don't stay in the power port very well, sometimes breaking the connection. I have my mount on the left side of my bars because I like it better on my left so I need something closer to my devices rather than running a cable across my bars anyway. The 3br powersports usb panel tapp provides a solid waterproof connection combined with their red band cables.
