Memory Card Slot
Old Jul 16, 2014 | 02:30 PM
mwegryn's Avatar
mwegryn
Originally Posted by surfnorthwest
I can use my Galaxy phone and stream the music via Bluetooth. I get drop outs at time though.
Not sure if the problem is on the bike or phone end (likely software related). I haven't had any drops that I've heard. Another option is to just plug the phone in and you'll be charging simultaneously. On short jaunts I usually just use the bluetooth, but on longer rides I usually plug it in, especially if I'm streaming something like Pandora.
Old Jul 16, 2014 | 03:34 PM
surfnorthwest's Avatar
surfnorthwest
I just put a 16gig thumb drive on the front USB. The screen now shows a pic of the cd cover and the fidelity is much better. Rock n Roll.
Old Jul 16, 2014 | 04:53 PM
YPD485's Avatar
YPD485
Originally Posted by WaucondaRider
Another option would be load all your music onto the memory card in your phone and then plug your phone into the Jukebox. Your phone would then act like a thumb drive and still charge.
That's fine if the phone (Note 3) fit in the jukebox.
Old Jul 16, 2014 | 05:20 PM
dwshort's Avatar
dwshort
You can also get a flash drive usb adapter to fit your type of memory card. Put your card in the adapter and plug it into the usb plug on the bike. I use 1 GB micro SD cards and put different type of music on each card. I got a small wallet to which holds 6 SD cards and when I feel like a change of music I just change the card. a 1GB card hold approx. 170 songs which can last all day.
Charcoal Pearl 2014 Street Glide Special
Custom Dynamics red LED's and Dynamic Rings with smoked lenses.
Vance & Hines Monster Ovals. HD Heavy Elite air cleaner.
Precision Billet Darkside floorboards, Derby and Points covers.
Kuryakyn curved license plate holder, Transformer grips.
HD Fork mounted Wind Deflectors. 10" HD Windsplitter windshield.
4 point docking hardware.
Old Jul 16, 2014 | 09:49 PM
p51bombay's Avatar
p51bombay
Make sure you are using an authentic cable if it is an iPhone. A majority of the cheap import cables do not work properly. The 30 pin connectors seem to work pretty well, but the lightning connectors not so much.
Standard iphone 30p cable is a PITA to stuff in there - I bought an off brand 3" long cable, it works fine and charges the phone and is easy to fit in there.
Old Jul 16, 2014 | 10:59 PM
surfnorthwest
What through me off on this SD card thing was on Harleys website under specifications it says. SD card via USB port.
Check it out in the screen shot below.
Old Jul 17, 2014 | 10:02 AM
dyna07custom's Avatar
dyna07custom
http://www.amazon.com/eForCity-Memory-Reader-Adapter-Smoke/dp/B000Z9R2QQ/ref=sr_1_5?ie=UTF8&qid=1405609214&sr=8-5&keywords=usb+to+sd+card+adapter http://www.amazon.com/eForCity-Memory-Reader-Adapter-Smoke/dp/B000Z9R2QQ/ref=sr_1_5?ie=UTF8&qid=1405609214&sr=8-5&keywords=usb+to+sd+card+adapter
as long as you have this you can do it
it does not say memory card plug in just says through USB
Old Jul 17, 2014 | 10:06 AM
mwegryn's Avatar
mwegryn
Yeah, why did they make it so small? My iPad doesn't fit either. C'mon you bought a gigantic phone!!
Old Jul 17, 2014 | 05:58 PM
YPD485's Avatar
YPD485
They will get larger, just like the new iPhone coming out soon.
Old Jul 17, 2014 | 08:09 PM
mwegryn's Avatar
mwegryn
And it'll still be a fraction of the size of the Note 3. You have bluetooth, just keep that cinder block in your saddlebag...problem solved.
