Passing lamps question.
Old Jul 20, 2014 | 08:03 PM
Axegrinder's Avatar
Axegrinder
Default Passing lamps question.
I know a lot of you guys out there with a Limited have had the passing lamps turned on so they stay on with the high beams. The question I have is . Do any of you who have them on also have the HD garage door opener too. If so does it work properly?
Old Jul 20, 2014 | 09:23 PM
EC145Pilot's Avatar
EC145Pilot
Yes, it works with no problem. Wired into the headlight circuit.
Old Jul 21, 2014 | 08:15 AM
Axegrinder's Avatar
Axegrinder
Thanks... Trying to wire a HD opener into My buddies SGS but the power flow is different on the Street Glide than the Ultra or the Limited...just looking for a work around. The local shops haven't figured out how to wire one in because of the difference yet either.. Same wiring harness but different power flow. I think it is just a BCM programming difference but they say there is nothing they know of to change and since they wont let me in the shop to muck around with the digital technician I guess I will either have to wire a relay in or wait for them to come up with an answer..
I kind of want to beat them to the answer because when I talked to them about the issue they said I must have wired it wrong because the SG and the Limited have the same wiring and said it was because I was a back yard mechanic not a trained HD Tech and I should leave it up to them. They didn't like it much when I pointed out the problem and they had to admit I was right and they didn't know how to fix it..
Thanks again
Old Jul 21, 2014 | 09:23 AM
surfnorthwest's Avatar
surfnorthwest
What is the part needed to keep the driving lights on with the high beams? Is this the same part for the opener also?
Old Jul 21, 2014 | 09:25 AM
KCwildguy's Avatar
KCwildguy
It's not a part, it's a change to the programming, it's run through the ECM.
Old Jul 22, 2014 | 02:32 AM
ke5rbd's Avatar
ke5rbd
Takes longer to hook up digital assistant than it does to turn on the full time passing lamp feature.
Ricochet59
Jun 16, 2019 02:47 PM
Gritz72
Jun 6, 2016 10:24 PM
rwb1
Feb 2, 2014 04:29 PM
geebake
Electrical/Lighting/Alarm
Mar 23, 2012 05:05 PM
TennRider
EVO
May 1, 2008 11:57 PM
