Any changes seen in the update?
Old Sep 4, 2014 | 10:10 AM
  #31
offthewall's Avatar
offthewall
Originally Posted by Coloradohunter
The only change I've noticed is the screen that says what software version I'm running used to say 1.17.4. Now it says 1.18.1.
Try zooming your Map in or out.
Old Sep 4, 2014 | 11:36 AM
  #32
riderideride's Avatar
riderideride
This could just be anecdotal. I did the update yesterday morning, then did about 450 miles, and noticed the below happening.
When infotainment is left in map mode for a while, select the "minus" button to zoom out, but it zooms in instead. It seems to zoom in to the closest extreme, skipping all gradients between, although I haven't selected the "plus" to confirm that it is at the furthest in. Happened probably 5 or 6 times yesterday. I'll be paying closer attention how to duplicate.
Old Sep 4, 2014 | 11:53 AM
  #33
offthewall's Avatar
offthewall
That is a reproducible new bug. Hitting the + OR - the first time will zoom the map all the way in. + or - presses after that function normally. UNTIL you restart, the it starts all over again.
This one actually bothers me more than any of the glitches before since I tend to zoom in/out often when using the Nav feature.
Old Sep 4, 2014 | 11:57 AM
  #34
WaucondaRider's Avatar
WaucondaRider
I agree. Could be considered a little bit of a safety issue because now instead of one or two clicks is could be a half dozen or so to get where you want. Granted it's all thumb controlled but it's still distracting you from paying complete attention to the road.
Old Sep 4, 2014 | 12:00 PM
  #35
offthewall's Avatar
offthewall
yep, I rolled back to 1.17.4 cause it was driving me nuts and taking too much attention from the road. Before, it was a single click once in a while to see an upcoming turn, etc but now it's a major pain.
Old Sep 4, 2014 | 12:02 PM
  #36
riderideride
That is a reproducible new bug. Hitting the + OR - the first time will zoom the map all the way in. + or - presses after that function normally. UNTIL you restart, then it starts all over again.....
Thanks offthewall. Good to know. Well not "good", but does brings me some comfort.
Old Sep 4, 2014 | 07:08 PM
  #37
JAMESAK51's Avatar
JAMESAK51
Originally Posted by Betteroff
I have the 4.3". Before it was hard telling the time in the daylight because the orange lines/border at the bottom ran across the lower half portion of the time display. Now after the update the orange border is gone and I can clearly see what time it is.
I had actually considered buying an aftermarket clock until now.
+1 If I'm remembering correctly my numbers used to be white with a blue gradient or fade and were really hard to read, now they're solid white and easy to read. It only took me like 3 days of riding to notice it after the update. Not surprising though, sometimes it takes me an hour and a half to watch 60 minutes!
Old Sep 4, 2014 | 08:57 PM
  #38
kc hog's Avatar
kc hog
Just checked mine, it does the same thing. Zooms way in.
Old Sep 9, 2014 | 11:16 PM
  #39
harleyjth's Avatar
harleyjth
+2
I noticed it as soon as I got on the bike. Much better!
jt
Old Sep 9, 2014 | 11:22 PM
  #40
nicliv's Avatar
nicliv
Dealer installed and changed nothing Oh it worked at the dealer 1st stop I made and on came the weather band again
IUOE ROB
2014-2024 Touring Models
22
Mar 15, 2016 04:38 PM
Jeff Hester
Aug 15, 2015 06:53 PM
scuba1954
13
Jun 8, 2015 07:08 PM
bigrobtemp
34
Mar 6, 2015 09:23 AM
AR15TomJefferson
Jul 5, 2014 09:09 PM
