Engine died While Doing 80MPH+…
Old Sep 15, 2014 | 03:48 PM
DC2009EGUC's Avatar
DC2009EGUC
Default Engine died While Doing 80MPH+…
on a busy los Angeles freeway on a dark moonless at night in the HOV lanes with no road shoulder…Could not figure out what happened, I kept rolling on the throttle thinking it went into limp mode, but to no avail, engine coasted in six gear until it came to a full stop with cars on my tail swerving right, avoiding to hit me & bike…
Panicked stricken, I kept pushing the start button and but to no avail, pushed both turn signals to enable emergency flash but would not turn on, finally remembered, ’14 and up touring are now a one push rocker switch located with the starter button…shifted tranny down finding neutral and walla “green” neutral came on push down on engine run/kill switch, hit starter button, engine came to life, shifted to first, looked behind, saw a distant car headlight closing in, rev engine, release clutch and got out there like a scalded cat…
Lessons learned if sudden loss of power happens:
1. Hit run switch to run
2. Pull clutch in
3. Hit start button and go…
I guess easy for me to say now in in retrospect, but on a dark night and seeing near misses happening before my eyes, & unable to see the handle bar switches to see the state of the switches; I had no clue that I accidentally hit the engine run/kill switch, & that was the root cause…man I have a new lease on life and just extended bike riding days…& nights…
Old Sep 15, 2014 | 03:54 PM
perki48's Avatar
perki48
All thanks to one of those "useless" government mandated switch's.
Old Sep 15, 2014 | 04:36 PM
J929626's Avatar
J929626
I think the order below might be better:
1. Pull clutch in
2. Hit run switch to run
Coasting, in gear, with the clutch engaged and then turning the switch back on could be as exciting as turning it off accidentally.
Old Sep 15, 2014 | 05:16 PM
skieverything's Avatar
skieverything
After turning the switch to the proper position , just let the clutch out and go. No need to hit the start button!
Old Sep 15, 2014 | 05:24 PM
RG Pilot's Avatar
RG Pilot
So are you saying that you accidentally hit the kill switch and that's why it died or is that why you couldn't restart it or both?
Old Sep 15, 2014 | 05:28 PM
JustDave13's Avatar
JustDave13
Yep, that's what he's saying, he accidentally hit the kill switch.
Old Sep 15, 2014 | 05:30 PM
skyhawk85u's Avatar
skyhawk85u
Sounds similar to what happened when I ran out of gas once on the highway on an old bike. Pull in clutch, reach down to switch to reserve fuel, let out clutch and engine starts back up. Exciting, though, for sure...
Old Sep 15, 2014 | 05:48 PM
jcapps's Avatar
jcapps
Back in the late 70's I had an ignition kill device on my van. On the Cross Bronx Expressway, fast lane the van died. My and my GF. Back then and given the time of the morning, the traffic was flying. Luckily I realized the kill device had come loose. Pushed it in and went!!!!!!!!!
Old Sep 15, 2014 | 05:50 PM
HarleyguyUltra2011's Avatar
HarleyguyUltra2011
At least you avoided any accidents and man enough to admit it was your fault and didn't try blaming Harley .
Old Sep 15, 2014 | 05:57 PM
Cobra1's Avatar
Cobra1
I have never actually used my kill switch. If I ever pushed it by accident I would probably tear the bike apart before I would look at that switch. Never really knew why it is there anyway.
