2018+ Softail Models Breakout
Horn
Old Aug 6, 2020 | 02:07 PM
  #31
listentothenighttrain's Avatar
Originally Posted by AJ88V
If the wiring or current supply is undersized, you would definitely see an advantage running a heavier gauge wire directly to the battery via a relay.
For grins, I just traced back the horn wiring and it goes to the Battery Control Module (BCM). Had to look that one up, but it looks like electronic controls for just about everything on the bike (horn, lights, accessory power, alarm, RFID, etc.) To me, that indicates that it probably uses electronic control on the horn and that would be limited to whatever power they designed it for. I suspect this is a FET control switch. The upside is that you're unlikely to damage anything if you do try to draw too much power, but if your new horn draws more current than the BCM was designed to deliver, the horn would sound weaker than if connected directly to the battery.
You would be a true gentleman and scholar if you stabbed the horn with a multimeter and figured out what it's draw is..
I'm wondering what the loudest horn I can hook up to the factory wiring would be.
Also, is there any disadvantage to mounting the horn to the side of the bike vs. behind the forks? How audible would it be to drivers on the opposite side of the horn while riding on the highway?
Old Aug 6, 2020 | 02:27 PM
  #32
jj14x's Avatar
jj14x
Thank you. That makes sense
Old Aug 6, 2020 | 02:29 PM
  #33
AJ88V's Avatar
AJ88V
No idea what the current limit is for the BCM.
The Wolo low tone horn says it draws 4 amps at 12 volts => 48 watts. https://wolo-mfg.com/horns/industria...-low-tone.html
Since Harley sells essentially the same thing as their "loud" horn, replacing yours is probably fine as far as current goes.
The wavelength (standard temperature and pressure) at 440Hz is approx 0.77 meters / 2.6 feet. Since your bike is about that tall and twice as long, it would probably block some of the sound if mounted on the side. Mounted on the front, there's not much that big to block the sound, so the horn should give good coverage pretty much everywhere in front of your bike, which is where you'd want other drivers to hear you.
Old Jul 29, 2024 | 09:17 AM
  #34
MARROCKS's Avatar
MARROCKS
6th Gear
Default How did you do the Horn Relpacement
Originally Posted by OldMike
Please tell us how this was done, as the horn removal nut sits behind some box that is hard to get off. Seems like you have to either remove gas tank and harness cables the connect to the black box or remove engine bolts. Please help.
Old Jul 29, 2024 | 09:56 AM
  #35
coppertop666's Avatar
coppertop666
I just replaced my horn on my Sport Glide with a Mini Screaming Banshee and it was super easy to remove the old horn.
Just pull the horn forward to "bend" the mount a little to access the nut, remove and install the new one and then bend back into position (if using the existing mount).
Old Jul 30, 2024 | 08:35 AM
  #36
99Blueflame's Avatar
99Blueflame
Nice, This the same setup that I used on my Sport Glide. Couldn't believe Harley put a Beep Beep horn on my bike. Sacrilege I tell Ya.
Old Aug 4, 2024 | 09:28 AM
  #37
m8deluxe's Avatar
m8deluxe
2nd Gear
Originally Posted by sumncguy
Has anyone found a horn that is .. well .. more realistic. Id like to find one like I have on the Wing. Those are as loud as a car horn. ... almost.
Original horn on my 19 Deluxe sounded like anemic Yugo. Replaced with older model Harley horn from ebay. Very loud with pleasing car-like tone. Mounted just above oil cooler with large black zip ties.
Lonely Drifter on a Harley Breakout
Feb 18, 2021 09:30 PM
meadows.harrison
Mar 25, 2013 08:12 PM
jarman
Feb 9, 2011 09:34 AM
t059736
Mar 17, 2010 03:25 PM
unclemunkle
Apr 22, 2008 10:22 AM
