2018+ Softail Models Breakout
Lowering 2018 Breakout
Old Mar 13, 2019 | 07:47 PM
Hogtyd12's Avatar
Hogtyd12
Stage III
Default Lowering 2018 Breakout
Anyone have any experience with lowering 2018 Breakout?
Old Mar 13, 2019 | 09:07 PM
Superdog3:16's Avatar
Superdog3:16
Only if ya wanna go broke on air.
Old Mar 13, 2019 | 09:57 PM
Hogtyd12's Avatar
Hogtyd12
Stage III
??? Not sure what you mean or how that answers
my question.
Old Mar 13, 2019 | 10:03 PM
Superdog3:16
I been looking and researching too. Seems for the most part, for Softail, is shotgun air shock and the sort. I did see one kit that you alter the stock shock. Do a search on here and ya should find it. If ya don't, I'll try to find the kit for ya.
Old Mar 13, 2019 | 10:12 PM
Hogtyd12's Avatar
Hogtyd12
Stage III
I have found the mono shocks that you can get 1" to 2" shorter which would lower, but how much I am not sure. I was hoping someone had already tried it.
Old Mar 13, 2019 | 10:19 PM
Superdog3:16
Me too. I'm subscribed. Lol
Old Mar 14, 2019 | 03:43 AM
Mark Faulkner's Avatar
Mark Faulkner
Check out air ride options.
https://shop.thunderbike.de/en/Thund...t-oxid-15.html
Old Mar 14, 2019 | 08:30 AM
Superdog3:16
Originally Posted by Mark Faulkner
Here's the high dollar stuff I was telling ya about.
Old Mar 14, 2019 | 12:44 PM
Blackp5ca's Avatar
Blackp5ca
I went with Platinum Air on my 18 Breakout, pretty happy with the air shock performance.
I know air isn't for everyone, I went with it because I love the look of a lowered bike but I also like to ride the bag off it.
My old Softail Blackline had a static drop with Progresive Suspension, looked great and the ride was pretty good with the progressive set up front and rear but came at a cost of ground clearance, carving up the back roads (well..as much carving as you can do on a softail) got a little dicey when your dragging pegs, kickstands and the primary case in the odd corner...it was always a pucker your *** in the tight corners and hope you had enough room left in the lean.
When I bought the new Breakout I decided on the air, never ran air before, wanted the lowered look but with function (I'm running the Thunderbike fender and it looks terrible in my opinion if it's not sitting close to the tire) This gives me the option to air it up to stock height to rip the back roads without worrying about scraping or catching anything.
With the Platinum system, it has height and rebound control in the bleed and feed system (two toggles, set the height with one and rebound with the other) so I found I could dial it in pretty good, none of the pogo feel you can get with air ride (It's not an Ohlins quality ride or anything..but it's pretty good, certainly no worse than stock but only marginally better...I felt like the oem shock was pretty good considering)
Price isn't too bad ($1,150), install was easy in the garage with simple tools, haven't had any issues with air loss.
Old Mar 14, 2019 | 08:54 PM
LIMike's Avatar
LIMike
I went with the progressive 465 on my 2018 slim. It dropped the back end about 2in. The new softail design allowed for more ground clearance so even with the 2in drop I'm still able to take tight corners with no issues.
