2018+ Softail Models Breakout
Engine light on after burnout
Old Jan 23, 2020 | 01:46 AM
2020LowRiderS's Avatar
2020LowRiderS
Default Engine light on after burnout
So today I did a small burnout when I got home and just now noticed When I start it my engine light is on? Does anyone have any idea why this could be ?
Old Jan 23, 2020 | 02:39 AM
Dan D.'s Avatar
Dan D.
Check the error codes. Google will tell you how to check, if you don't know already. My guess is P0522 and P0523.
Old Jan 23, 2020 | 06:00 AM
RANGER73's Avatar
RANGER73
Doing stupid **** sometimes gives unexpected consequences. Hope it's nothing serious and you resolve the issue.
Old Jan 23, 2020 | 06:34 AM
Mchad's Avatar
Mchad
If the OP is asking that question, I'd say it's pretty unlikely he knows how to check for codes. So:
https://www.wilkinsharley.com/--Chec...rley-Davidsons
Old Jan 23, 2020 | 07:16 AM
24v's Avatar
24v
Why would he get a oil pressure switch high or low code from doing a burnout?
2020LowRiderS are you sure it isn't your ABS light that is on? The back wheel spinning while the front isn't will turn that light on.
Old Jan 23, 2020 | 07:22 AM
Dan D.'s Avatar
Dan D.
Because that is probably the most common faulty code... Just a guess.
Old Jan 23, 2020 | 07:23 AM
Mchad's Avatar
Mchad
He said the light was on when he started the bike. Assuming that was after the wheel spin so its probably wouldn't be an ABS warning, right?
Old Jan 23, 2020 | 07:43 AM
24v's Avatar
24v
I have had mine stay on for a few ignition cycles on my Road Glide before. Haven't done many burnouts on the LRS yet though.
Old Jan 23, 2020 | 07:48 AM
2020LowRiderS
Is definitely the check engine light It came on when I started bike about an hour later.
Old Jan 23, 2020 | 07:52 AM
2020LowRiderS
thanks
