2018+ Softail Models Breakout
M8 Softail Slim - Max rear tyre (tire) width
Old Feb 10, 2020 | 03:45 AM
SlimFranky's Avatar
SlimFranky
4th Gear
Default M8 Softail Slim - Max rear tyre (tire) width
Just wondering if anyone can help with what tyre width would fit on ‘18+ Softail Slim without modification, on standard rim.
pretty sure 160 would fit no issue but could 170 or 180 be a possibility? Not looking to change tyre profile 80B
thanks
Old Feb 10, 2020 | 04:19 AM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
Someone here just did a 200mm on their slim.
https://www.hdforums.com/forum/2018-...2018-slim.html
Old Feb 10, 2020 | 05:15 AM
HKMark23's Avatar
HKMark23
Something you "might" need to consider if you're not installing the tire yourself or having your Indie do it, some HD Dealers won't install non-spec tire sizes. I have to have my Indie install the 250's on my 2014 Breakout. The Dealer will only install a 240.
Old Feb 10, 2020 | 07:29 AM
LIMike's Avatar
LIMike
I'm sure all dealers are different but my local HD dealer did all the work to my bike.
When I was running the stock fender before I went with the Ricks 200er my dealer told me 180 would hit but I could probably do a 170 but it would be close.
Old May 22, 2025 | 04:24 AM
bigred2828's Avatar
bigred2828
Stage I
Default Rear Tire
So, I am currently waiting for the pieces to come in from the mail. I ordered rear fender struts and a 2018 Sport Glide rear fender for my 2018 Softail slim. Since both are Softail frames and fenders appear to be similar except the sport glide takes a 180-rear tire, I am hoping to simply swap out the fender struts and fender and be able to put a 180-rear tire on with no clearance issues. I will admit even through Ebay the rear fender was pricey, however, it was still way cheaper than the big tire conversion kits you see available.
I will let y'all know what the outcome is when it gets finished.
MARCUS 79
Mar 6, 2025 12:44 AM
tmac00333
Mar 14, 2013 07:38 PM
blackbelt2
Wheels/Tires
Jun 9, 2011 01:45 PM
joshh
Oct 4, 2010 09:14 AM
rip
Apr 3, 2007 09:44 PM
