2018+ Softail Models Breakout
FP3 - Anyone have any concerns about it?
Old Apr 20, 2020 | 11:23 AM
MoneyFor's Avatar
MoneyFor
Originally Posted by Andy from Sandy
Do you get a return on your investment with the tuner?
If you plan on having many bikes and you plan on keeping a few at a time I would look at getting the PV as you only need to get additional licenses and not the tuner hardware.
If this is your one and only motorcycle then you pays your money...
I have a FP3 per Harley so I have 5 pcs at this time, a bike is not an investment neither are the parts you buy for them, it is al a waste of money
Oh yeah I have a PV to, I bought that one one for my FXFBS and took it straight of again and bought another FP3, the PV is stored to see never
daylight again.
Old Apr 20, 2020 | 12:20 PM
Hulkss's Avatar
Hulkss
Originally Posted by SoCaRider
Im confused if this is for dyno tuning only or If I can auto tune on the phone still? Thanks
The wideband tuning kit is the ideal solution for road tuning as you can tune the entire operating range with closed-loop O2 sensor feedback. You get a perfect road tune using your phone and then switch back to the stock narrowband sensors which now have near perfect VE tables to work with.
Old Apr 20, 2020 | 12:48 PM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Once in autotune mode the FP3 works the bike in closed loop mode. It is probably why V&H tell you the engine might run poorly whilst it is doing its work.
The difference is that the wideband sensor can give an exact value of how rich or lean the mixture is as opposed to the narrow band that only informs rich, lean or ideal.
Old Apr 20, 2020 | 01:19 PM
Hulkss's Avatar
Hulkss
With wideband tuning, the FP3 can tune directly to the target fuel table over the entire operating range. Autotune mode is completely different with the wideband kit.
Old Apr 20, 2020 | 01:20 PM
SWMB's Avatar
SWMB
You asked for opinions so here's mine. Just buy a Power Vision right up front and save having to do it later after already spending cash on the FP3.
Old Apr 20, 2020 | 01:27 PM
Hulkss's Avatar
Hulkss
Here is a list of what you can now tune with the FP3. What is missing?
Primary Throttle Blade Control
Secondary Throttle Blade Control
Switchover Gear
Throttle Limit vs Gear
Front Cylinder VE
Rear Cylinder VE
Front Charge Dilution Effect
Rear Charge Dilution Effect
Air Fuel Ratio
Acceleration Enrichment
Deceleration Enleanment
Closed Loop Range
Closed Loop Min Activation Temp
MAP Load Normalization
Intake Valve Opening
Intake Valve Closing
Adaptive Control Min Temp
Front Cylinder Spark Advance
Rear Cylinder Spark Advance
Spark Adjust by Engine Temp
Spark Adjust by Air Temp
Spark Adjust by Head Temp
Adaptive Knock Retard
Max Knock Retard
Knock Control Min Activation Temp
Knock Control Deactivation Temp
Idle Spark Control Gain
Idle Spark Control Max
Front Closed Throttle Spark
Rear Closed Throttle Spark
Closed Throttle Max TPS
PE Air Fuel Ratio
PE Spark
PE Disable RPM
PE Enable RPM
PE Disable TPS
PE Enable TPS
IAC Crank Steps vs Temp
IAC Crank Steps to Run
IAC Warmup
Idle RPM
Injector Size
Engine Displacement
Rev Limit
Gear Ratios
Old Apr 20, 2020 | 01:43 PM
SoCaRider's Avatar
SoCaRider
Great info Thanks 👍
Old Apr 20, 2020 | 01:44 PM
SoCaRider's Avatar
SoCaRider
Excellent excellent thank you 👍
Old Apr 20, 2020 | 02:47 PM
Gordon61's Avatar
Gordon61
Can you log data, and edit maps offline on a computer with these things yet? [EDIT: ADD] ...and what about logging spark knock?
Old Apr 20, 2020 | 04:14 PM
Hulkss's Avatar
Hulkss
As far as I know the FP3 tuning software is for your phone or an iPad. Most users seem to like it as it was developed for that environment. You can edit maps offline on either device.
I only know of using a real time sensor display of ignition timing to look for knock retard. You can run a screen recording while using the sensor data display that has four channels set to front spark advance, rear spark advance, RPM, and Manifold Absolute Pressure.
This is everything you need to check the timing. Just playback the recording after you ride. Good enough for a home user.
