2018+ Softail Models Breakout
Power Vision Install on 18' Fatboy
Old May 26, 2020 | 12:24 PM
jfl330's Avatar
jfl330
Default Power Vision Install on 18' Fatboy
Curious if anyone has installed the Power Vision on their 18+ Fatboy and if so, how did you route the cable up to the handlebar?
Old May 26, 2020 | 02:10 PM
FatBob2018's Avatar
FatBob2018
I put one on a Fat Bob, so not exactly the same, but same frame. Pull the tank off, then follow the electrical harness, occasionally zip-tying to the main electrical harness.
Old May 26, 2020 | 02:30 PM
jfl330's Avatar
jfl330
Is there any documentation on how to remove the tank?
Only have the bike a few months and not sure how this is done.
Old May 26, 2020 | 03:04 PM
FatBob2018's Avatar
FatBob2018
It's really simple to do. Documentation is in the Service Manual.
If you don't want to get the Service Manual, the process is:
1) Undo and remove the bolt at the front of the tank, and the bolt at the rear of the tank. 9/16" wrench.
2) Raise the tank up by wedging a block of wood under the rear of the tank.
3) Disconnect the fuel by pushing the large round silver quick-release connector (on the tank, left side) up and pulling down on the tube.
4) There's a vent next to the quick-release connector, just pull the tube off.
5) There's an electrical plug located closer to the front of the tank, on the frame, for the fuel pump. Disconnect that.
That's it. Pull the tank up and move it out of the way. Easier to do if it's empty, but it's not so bad even if it's full, it's just a lot heavier.
Note: I don't know how the Fat Boy's gauges are connected, I assume it's the same way mine is. If the cable to the instruments is too short to set the tank aside or have someone else hold it while you finish the wiring, then you'll have to remove the console off the tank and disconnect the cable from the speedometer.
To reinstall, reverse the above procedures. Once you've done it a couple of times, it's a few-minute process.
Old May 26, 2020 | 05:27 PM
DonN's Avatar
DonN
Dont really need to remove the tank. Just removing the bolt at the bottom and tilting it up will give you enough room to route the cable and zip tie it. I used it for a while, now with the tune running well, I removed it from the bars.
M8Thunder
Aug 21, 2019 06:10 AM
Merkel
Jun 12, 2012 03:22 PM
mccostlin
Softail Parts
Oct 4, 2011 09:57 AM
tnshannon
Nov 10, 2010 10:45 PM
stevieg
Motorcycles For Sale
Dec 8, 2009 08:17 PM
