2018+ Softail Models Breakout
Fp3
Old Oct 23, 2020 | 07:52 PM
Keifermaan's Avatar
Keifermaan
Stage II
Default Fp3
Has anyone used the O2 sensors upgrade with the FP3? If so how does it work?
Old Oct 24, 2020 | 12:07 AM
Hulkss's Avatar
Hulkss
The Fuelpak Pro accessory tunes a bike using included wideband sensors. You then put the stock narrowband sensors back to ride. You can then continue to tune additional bikes, each bike needs its own FP3. The FP Pro can be used on any number of bikes for wideband tuning.
https://fuelpakpro.vanceandhines.com/
I use the H-D Smart Tune Pro system where the wideband sensor system stays on the bike.
Old Oct 24, 2020 | 11:47 AM
Keifermaan's Avatar
Keifermaan
Stage II
Default O2 sensors
I know what theFP3 does. I was at the Harley dealer and Vance and Hines sells an upgraded O2 sensor. It is very expensive I was inquiring if anyone has used it and if it is worth it.
Old Oct 24, 2020 | 02:24 PM
Hulkss's Avatar
Hulkss
I have tuned bikes with and without wideband sensors. You can get a much better tune with wideband sensors. The high power portions of the engine operating envelope have air fuel ratios that are too rich for narrow band sensors to read.
After tuning, operation with narrow band sensors is fine. I would say the Fuelpak Pro system is worth getting.
Old Oct 26, 2020 | 07:47 PM
SoCaRider's Avatar
SoCaRider
And that wide band does not stay on the bike only for dyno tuning unlike my PV TT-7 wide band that does real time on the bike
Old Oct 26, 2020 | 08:50 PM
Hulkss's Avatar
Hulkss
Some say that after tuning with wideband sensors, assuming accurate VE tables, the bike will run better using narrow band sensors than wide band.
johnl111
Jun 6, 2016 10:46 AM
kamkam2
Jan 25, 2013 05:50 AM
soft 02
Jul 18, 2011 09:02 PM
nevil
Jun 5, 2010 03:55 PM
thundergod
Aug 20, 2008 07:19 PM
