Today I was riding with some friends and downshifted like I was always told not to do I down shifted with the clutch, released the clutch fast and immediately went to 100% throttle. Did not revmatch just basically dumped it. Nothing felt wrong with the bike afterwards but I also know it wasnt proper procedure. I guess Im more worried about how stout the drive train is and if thats something that would hurt this bike?
also Ive been reading on here that letting the motor slow you down vs rev matching and using more brakes is hard on the motor and can cause run out crank issues. Is there any truth to this?
I downshift 100% of the time. ALWAYS like in ALWAYS. Rarely to pass anyone since my '17 Ultra Classic has plenty of power.
Normally I run my bikes up to 100K in 3 years then trade them in. ONCE ever, when I had maybe 80K - 85K I downshifted in a police escorted ride on the highway, when all of a sudden I lost ALL my gears.
Bottom line was the spline hub. Abt $900 to repair. I think (I am not positive) but I think that 1 time ever I wore out the spline hub was due to downshift. But keep in mind, EVERY TIME, 100% of the time, when I ride I am downshifting.
It saves the brakes and I like the sound and feel.
I think it is FINE to downshift to pass someone or slow down. And I nvr that I am aware of used up tranny fluid or burned/discolored the tranny fluid.
I dont think people are understanding what OP is saying. From what Im understanding is that he was told not to rev it up and dump the clutch on a downshift which is exactly what he did.
I wouldnt do it excessively but its not going to ruin your clutch. Always try to rev match even if youre planning on gunning it afterwards. Youll probably either spin the tire or bog down the engine before you break anything.
It sounds more like the Op pulled in the clutch…downshifted a few gears…and then dumped the clutch. If that’s what you did don’t do that, because you can:
- mechanically over rev the engine, and throw a piston up your butt
- lock the rear wheel, and have it slide out from under you
- break something…on the bike or body
If you are going to downshift more than one gear:
- make sure that won’t over rev the engine
- let the clutch out slow enough to let the engine speed come up reasonably fast…not instantaneously. Or rev match…that means to rev the motor up to the speed that the new gear would put it in.
DONT JUST PULL IN THE CLUTCH, STOMP DOWN THE SHIFTER A BUNCH OF TIMES, AND THEN LET THE CLUTCH FLY…!!!!
Here is a good thread about downshifting. If you don't match RPMs on your downshift it increases rear tire wear. If you're not careful and drop into a lower gear than you think, in a turn, you may skid the rear wheel. One time I thought I was downshifting from third to second, but really I was downshifting from second into first, and that was exciting. And not in good way. https://www.hdforums.com/forum/touri...r-no-blip.html
