2018+ Softail Models Breakout
Breakout Suspension
Old Oct 4, 2021 | 01:23 PM
ArizonaKid's Avatar
ArizonaKid
Default Breakout Suspension
I recently upgraded the suspension on my 2019 Breakout by replacing the OEM shock in back with a Progressive 465 w/RAP and the front with Ohlins cartridges. I did the work myself, which was relatively easy with the right tools and such. Did the same on my Road Glide using all Ohlins pieces and couldn't be happier with the results on both bikes. For anyone contemplating the same work on your Breakout the stock shock length is 12.5" and I went with the Progressive 12.6" version, which is right on the money. The 465 is offered in multiple lengths in case you want to go up or down. Ohlins also has frontend lowering cartridges, or you can simply raise or lower the fork tubes in the triple clamps.
