2018+ Softail Models Breakout
Softail frame question
Old Oct 17, 2021 | 08:30 PM
DCR03USMC's Avatar
DCR03USMC
Stage II
Default Softail frame question
Does anyone know if the softail lowrider s and softail fat bob share the same frame/swingarm? I am looking at swaping a fat bob monoshock with the bungking monoshock riser to my lowrider s. I know that the fat bob shock is taller than the lowrider s. Was wanting to get the extra lift in the rear by swapping the monoshock as well as the riser extension.
Old Oct 17, 2021 | 08:42 PM
Hulkss's Avatar
Hulkss
The maximum shock length is 13.5". Any longer and the swingarm will hit the transmission case (based on my Heritage model).
Old Oct 17, 2021 | 08:50 PM
DCR03USMC's Avatar
DCR03USMC
Stage II
The actual monoshock I picked up for the swap is from a Heritage which I know is the same length as the Fat bob. The reason I was asking if the frame/swingarm are the same on fat bob and lowrider s is because I know people who have installed the bungking monoshock riser on the fat bob without any issues. So in theory if they share the same frame/swingarm then it should fit on my lowrider s with the Heritage shock. Just curious if anyone knows for sure before I pull the trigger on the bungking extension and a spring compressor.
Old Oct 17, 2021 | 10:36 PM
Hulkss's Avatar
Hulkss
Just look here and compare the part numbers: https://partsfinder.onlinemicrofiche....asp?make=hdmc
stemple
Sep 22, 2021 11:48 AM
Curated Content Editor
Dec 26, 2020 10:57 AM
Brayden
Oct 8, 2020 08:08 PM
jmilb10053
Sep 5, 2017 01:04 PM
benwiggin2
Sep 28, 2008 05:00 PM
