2018+ Softail Models Breakout
Heated clothing installation
Old Oct 26, 2021 | 12:56 PM
rainsong's Avatar
rainsong
Default Heated clothing installation
I've had a Gerbing setup for a long time on my '97 Fatboy and was planning to move it to the '21 Heritage. Obviously the battery is not nearly as accessible on these new bikes as what I'm used to.
Is connecting straight to the terminals still the preferred method for 12v accessories like heated jacket plugs or is there some other accessory wire to tap into? It looks like I'd have to remove the battery to even get to the positive terminal.
Old Oct 26, 2021 | 01:11 PM
pjbuilder's Avatar
pjbuilder
I went straight to the battery terminal using the fuse from the glove manufacturer on my Sport Glide last year for heated gloves. It was a pain in the *** but if nothing else I learned how to remove the battery. Tried to get to the positive terminal without actually disconnecting the battery and ended up dropping the damn screw so had to pull it anyway. I would imagine the Heritage is equally as tight.
Old Oct 26, 2021 | 02:56 PM
bronxbill's Avatar
bronxbill
You don't have to remove the battery, but you do have to remove the plastic cover that holds it in. Once the cover is out you can access the positive terminal. There are several YouTube videos that show battery removal; they will show you how to get the cover off. It is a little bit of a PIA
Old Oct 26, 2021 | 07:22 PM
rainsong's Avatar
rainsong
Got it installed. Definitely much more of a pain than the old bike but it still took me less than an hour I think.
I had a permanent dual controller mounted in the console of my old Fatboy but realized since the HC doesn’t have an actual split tank and has a narrower console that wasn’t gonna be easy to fit. For now I’ve just wired a coax pigtail and may add a wireless controller at some point.
Old Oct 30, 2021 | 11:38 AM
Uncle G.'s Avatar
Uncle G.
It's definitely worse than previous Softail models. The first time I went to remove the battery it took me about 40 minutes to figure it out. After a couple of times it's about a ten minute job. Still more complicated than it should be, like nearly everything else on the bike.
benson1603
2014-2024 Touring Models
Jan 27, 2016 11:41 AM
ROCKOUT Rocker Products
Dec 2, 2015 03:40 PM
Mikekoz13
Mar 6, 2012 12:38 PM
Superfly3176
Feb 5, 2012 09:56 PM
Ace07FXDL
Feb 20, 2008 03:22 AM
