Led Turn signal
You can also swap the front signals over and see if the fault switches over with them to check the signal unit.
Front Signature LED Turn Signal Inserts - 67801184 | Harley-Davidson EU
I think the fronts should look like these but these are described as for the rear.
Rear Signature LED Turn Signal Inserts - 67801329 | Harley-Davidson EU
So
and rear[/size][size=17px]67801151.
I managed to remove the front signal and swapped side but still it works just the yellow signal light[/size]
One front signal, 67801184 has position light and turn signal?
One front signal, 67801184 has turn signal only?
You need to swap both signals over, left signal to the right and right signal to the left. This will show if the signal or the wiring is faulty.
If you have swapped both over and the signal that had position and turn, still has position and turn, then the fault is not wiring related.
If you have swapped both over and the signal that had the position light fault, still has the position light fault, that signal is faulty.
This takes two minutes to say and ten minutes to type so it reads logically
If you really want running lights using OEM, then you would need someone to buy and ship them from the US. Failing that the aftermarket awaits
Thank you for the help
I realise the one I got is amber/amber and the US model for my fxlr 2018 it should be [size=17px]67801148 amber/white[/size]
The 67801184 doesn't say it has a position light, but says there is a "signature ring" ...whatever that is. Given there are only two wires best I can see is it flashing along with the centre LEDs
If you want positions on the front you will need new lights and cables down to the tank
The connector in the neck of the bike does have three wires - IIRC black, blue and white. The black and blue are the ground and power for the turn signal. The white is power for position lights.
But - on EU bikes, the wiring from the connector in the neck to the turn signals is only two wires - the blue and black. If your replacement turn signal has three wires, and you bring all three back to the connectors in the neck and fit them accordingly, then you can run turn signals with position lights. If only two wires, then turn signals is all you get.
On my old FatBob, I fitted HeinzBikes LED turn signals with position lights. These had three wires, all of which went all the way back to the connectors in the neck of the bike. Turns signals and position lights, no problem.
By the way - how are you doing Gordon?
