Fuel Gauge INOP After Flash
I flashed the ecu with a step up on the throttle advance, and after the flash my clock reset, and my fuel gauge is inop with remaining range now shows Low.
Is this normal. Will it correct itself after a few miles or do I have to reset it?
I hope it just needs to recalibrate or something. Or is there a precdure to reset the gauge like the clock.
I believe this is my exact issue as I just realized that my cruise was also INOP during my ride into work today.
Will do this procedure and report back.
I decided to drop by the dealer and ask them if they have any suggestions. Nope! This particular HD dealer says they dont work with the Fuelpak, and if they take a bike in on trade and it has one, the chuck it. Okay then
The SA did say something interesting. He said what they would do is flash it back to stock. Now, I knew what then meant, theyd flash it back to stock, tell me they got the fuel gauge to work, then they would say, you got an exhaust and filter, you need to buy a PowerVision for $500, $150 diag, and $150 to reflash back to Stage I.
This is now the option of last resort. Now, I had vaguely remembered someone had some problem, and they had to flash back to stock to fix it. In there case they had to replace all the aftermarket stuff which was a pain. But I have a stage 1, its just an exhaust and airfilter. I will flash back to stock and see what happens.
I flash back, well what do you know, gas guage and cruise are working, and, I didnt have to reset the clock. I reflash again for the exhaust and air filter stage I. BAM! Fuel Guage still working, cruise working, clock didnt have to be reset.
Thats how I fixed it, flash back to stock, then re-flash to Stage I.
BTW, I did not reflash to the advanced throttle. Im leaving well enough alone. Xl
the moment you open up the intake you bike will run lean, so something has to compensate. It the ecu can do it alone, cool.
The Fuelpak was already on the bike when I bought it, and the dude I bought it from installed the stage I parts at time of sale. I can only assume he did that to keep his warranty. If it didnt have the stage I parts I doubt I would do any of it. Now that I have them for free, will I do a stage II? I dont know. Im considering it.
Anyway. I confirmed the Fuelpak will not load correctly with the throttle advance, I was able to recreate the issue. Once the fuel guage is INOP the the only way to get it back is to flash back to stock and start over without the throttle advance.
The part that bothers me is I dont know if I can trust the Fuelpak for anything else. I do like the view sensor data feature. If I go stage II it would be nice not to have to buy another tuner.
I contacted V&H and the tech said the gauge was dissabled in the new tune. He reenabled it and I downloaded the new tune and it has worked since.
He said it was in the tune area that we could not modify so they had to do it. Basically they forgot to enable it in their canned tune, ooops.
