2018+ Softail Models Breakout
B2177h Code 18 FXFBS
Old Sep 24, 2022 | 12:19 PM
AmmoILMC's Avatar
AmmoILMC
Stage I
Default B2177h Code 18 FXFBS
Good afternoon, I noticed the other night that my running lights were illuminated, even though the bike was off. They were not as bright as they usually are, when the bike is running, but they were lit enough to be noticed. After checking out, some connections and unplugging and replugging in the turn signals, I decided to check the diagnostic through the speedometer. I had the code B2177H and upon further inspection, that is a security antenna code. I don’t have a security system on my 18 FatBob other than my keyfob battery (which was just replaced), and to no avail, the lights are still on. I didn’t know if anybody else ever had this issue on a 18 or higher softail, and if you did, how were you able to fix this issue
