2018+ Softail Models Breakout
Fat Boy upper fork caps
Old Oct 7, 2022 | 02:51 PM
Doublefelix's Avatar
Doublefelix
Default Fat Boy upper fork caps
Got my FLFBS back from service, and I notice the fork cap nuts are in different positions. My OCD is not letting it go. Is there a way to turn one so it indexes the same as the other? Can I back one off 1/8 turn without issues?
Old Oct 7, 2022 | 05:23 PM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
They have a torque value. So you'd have to unscrew the cap completely and do it again.
Old Oct 8, 2022 | 09:31 AM
Doublefelix
won't backing them off or removing them and reinstalling result in the same position when re-torqued?
Old Oct 8, 2022 | 09:33 AM
FranBunnyFFXII
Depends on the kind of threading.
You can get some fork caps for them and then spraypaint them silver/brushed aluminium, that should be able to fix your itch.
Old Oct 8, 2022 | 09:42 AM
Doublefelix
Old Oct 8, 2022 | 12:02 PM
WS6_Keith's Avatar
WS6_Keith
It should, but there is generally a toque spec range. On my 2011, it's 60-70ft-lbs, so if you had to, you could do one 60 and one 70 or whatever is necessary to get the flats where you want them.
Old Oct 8, 2022 | 12:09 PM
Uncle G.'s Avatar
Uncle G.
Put the bike on a lift or elevate the front wheel. Remove the rear fork covers and loosen the pinch bolts then rotate the fork tubes until you’re happy with the orientation. Do one side at a time.
Either that or get help for your OCD.
phdpimenta
Feb 28, 2022 10:36 PM
Gibler77
Jun 15, 2015 08:42 PM
Hey Zeus
Oct 29, 2012 04:06 PM
per sweden
Dec 21, 2011 09:54 AM
