Installing Rougue Industries Daytime Running Lights on a NZ Low Rider S
Does anybody in New Zealand know how to install RRI led indicators / running lights.
My 2021 low rider s only has a single pin bulbs to the front indicators not the 1157 fitting, appears to be different for NZ models or is their a way around this ?
I think pretty much all the 2018+ Softails have three wires run up at least as far as the neck to allow 3 wire lights at the front. So you can fit a 2 way bulb to the fronts (and rears) but may need to run 3 wires from the turn signal body to the connectors in the neck.
Appreciate your input. ill check that out, I tried asking at the Harley shop but a got the blank star from the parts guy, figure ill try another Harley shop. Custom Dynamics make a international led front indicator/running light and it comes with an extra wire, ya just have to run an extra wire to take a feed from the headlight. I really wanted the RRI or Harley Halo though. Anyways I'm gonna look into your suggestion further.
