2018+ Softail Models Breakout
Fitting SE spark plug cables
Old Jul 13, 2023 | 10:26 PM
murphc13's Avatar
murphc13
Default Fitting SE spark plug cables
Just a question for the good people on the forum.I got a set of SE spark plug cables and the service manual recommends
●removing the tank
●removing the main fuse
●purging the tank
and so on.
However after looking at the cylinder heads of my 22 FXFBS it looks like I could remove the stock cables without removing the seat/tank and so on.So the question is if I can remove and fit the se cables without doing all the other bits recommended in the service manual is it ok to do so?
Old Jul 14, 2023 | 03:55 AM
Phil13's Avatar
Phil13
Left side plug leads no problem.
The plug leads on the right are set quite deep. There are two ways to remove them.
Method 1, Use something like this
to grip the plug cap and pull them out. This tool needs to be nearly vertical to grip the plug cap, so clearance with the tank on will be a problem. But there are a thousand variations of plug lead removal tools that may allow you to do it with the tank on.
Method 2, You could leave the tank on and just rag the old leads off and hope they stay in one piece and they don't leave the plug cap still on the plug.
Sorting out the plug leads with the tank on is a bit of a faff, but it can be done.
Pays yer money and............
Old Jul 14, 2023 | 04:02 AM
murphc13's Avatar
murphc13
I'll just remove it man.It just really looks like the rh side plugs could be removed by hand.Thats all.
Old Jul 14, 2023 | 05:22 AM
jake24lt's Avatar
jake24lt
Use dielectric grease on the boots, so when you have to take them off again its not a struggle.
Old Jul 14, 2023 | 05:26 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Just curious as to why you want to replace the wire set on a 2022 bike?
Old Jul 14, 2023 | 05:29 AM
murphc13's Avatar
murphc13
Probably because of boredom!
Old Jul 14, 2023 | 06:14 AM
Iceman24's Avatar
Iceman24
For my 2020 Heritage, I just raised the rear of my tank (careful of fuel line) & it allowed plenty of room to remove/install wires.
For me, swapping wires, I wanted them to match my purse & boots.
JK - had some HD gift cards & the SE wires were on sale.
Old Jul 14, 2023 | 06:22 AM
murphc13's Avatar
murphc13
I git the black ones with the 'orange' writing on them.I have an orange thing foing on with my black Fat Bob.I was hoping the se cables would be more orangey butwhat can ya do.
Old Jul 14, 2023 | 07:23 AM
strych9's Avatar
strych9
Then why are you here asking for advice? It's so easy to remove the tank, not sure why you wouldn't. But you do you, man.
Old Jul 14, 2023 | 07:28 AM
murphc13's Avatar
murphc13
Well I mentioned about the manual recommending to remove the fuse and purge the tank also.But it seems that isn't necessary also.I guess I'm looking for info from people that know Harleys better than i do.
