New here.
Used to try traveling on it. It'd have me pissing blood for a few days when I'd do that.
But yes, my Heritage vibrates more at interstate speeds than my Road King did.
And my Road King shook at idle far more than my Heritage does.
The venerable Widow Maker, or Quick and Dead, etc.
Truly brutal bike. I'll never forget it. 😆
The Water Buffalo was in interesting contrast of a two-stroke triple in comparison to the Kawasaki. A much better behaved bike.
All quickly eclipsed by the inline-4 4-strokes like the CB750 and KZ900 and such.
There are a number of posts of folk finding engine mounting bolts loose and sometimes missing. Addressing this reduces the vibration on their bikes. When I can, I'm going to check mine. Just something that each of us can do in the pursuit of vibration reduction.
Something else would be bar weights. I don't see any good or ready way to install bar end weights on the throttle side. Though a sleeve insert might work on the throttle end, same for those running heat grips to deal with the controller on the clutch side. But something attached to the mirror mounts might help and be easily attached. It also might break things. I may try some experiments at this location with some flat stock or such, just to experiment.
I know part of the issue I have with the vibration through the boards is their size, position and angling. They are too level, a little too low, too close to the bike, and small. It has me often dangling my feet off to the sides of them, defeating the vibration isolating inserts. So extensions to get them out further should help. And maybe some brackets inserted in between the boards and those extensions so I can move and angle the boards. And maybe even trying other boards, like the bigger ones from the touring bikes. I've also thought about experimenting with things on top of the inserts, to move my feet that way. Zip tie things like a wooden board in place to see how it works for me. Something any of us could do as well.
Seats play an interesting difference in the vibration, as well basic comfort. I've run the stock seat, a Reduced Reach Seat, and both Sundowner seats (solo and dual).
The stock seat was ok, but not an all day comfortable seat to me. I could ride it all day, but it wasn't pleasant. I would splay my legs on it, positioning my feet poorly on the boards. It also transmitted some vibration to my butt. Not much, but some.
The Reduced Reach seat was a firmer foam, and narrower. It was oddly wide and sharp edged at the front, making it quite uncomfortable to put my feet down at a stop, or to hold my legs in against the tank. So, poor foot positioning on the boards, increased foot vibration.
The Sundowner, both types, have a soft outer layer of foam and a narrow nose. The reduction in vibration and butt discomfort is pronounced. They also let me better position my feet on the boards, which substantially reduced my foot vibration.
Just some food for thought regarding the vibration reduction some of us would like.
