How much cat to remove?
If it's just a hole punched through the matrix, that's illegal and they will eventually be prosecuted for it.
If the matrix is shaved down, unless they've the testing to show it's still effective, that too is illegal and they'll eventually be prosecuted for this. I doubt they've done the compliance testing. They certainly don't mention it on their web page. The catalytic converter matrix, being brittle, is demanding when it comes to grinding it down without breaking it up. Sure, it can be done, a grit faced disc will do the job, just like a glass or ceramic shaper uses. But would they do this? For such a cheap price? And would they not brag about it on their web page?
Makes me suspect they actually aren't doing anything with the catalytic converter after all. But, if someone has a picture of this catalytic converter modification, well, we'll see what we see then.
I never intended to leave it like that. And it was definitely a performance hit. Not huge, but obvious. Exhaust can't add horsepower, it can only rob it with reversion. I added an open baffle back in to dampen the open potatoe gun sound and lollipops to correct the obvious reversion. The sound is better, and it is a performance increase better than stock. I actually put very little stock in such things, but it is... Dare I say, significant, and obvious. I already had less restriction and an open pipe, so it must be reversion.
Now that if had it for a while, I have tired of it. Yes, it definitely sounds better than stock, but it kind of drones on. It's all deep with no rasp. I never wanted loud just to be loud. I hate obnoxious pipes. I want a good sounding throaty exhaust. It was a temporary experiment. I always planned on full exhaust. It was worth it.... for temporary. If I wasn't going full exhaust, I would replace them with proper slip-ons that have at least been tuned to sound right and don't induce reversion.
If you like the sound... Fine. Don't add anything else... But get some lollipops, and you will see for yourself.
What is also proven is big open pipes on naturally aspirated engines are detrimental to performance. Large diameter pipes decrease velocity... That hinders scavenging.
