2018+ Softail Models Breakout
Foot peg problem
Old Sep 23, 2024 | 07:37 PM
Shiv's Avatar
Shiv
Stage III
Default Foot peg problem
What size Allen wrench removes '23 Heritage rear footpegs? How do I get the one I buggered up? TIA
Shiv
Old Sep 23, 2024 | 07:49 PM
OldMike's Avatar
OldMike
Shiv
Thought it was a Torx, like a T45, not an Allen.
Old Sep 24, 2024 | 08:53 AM
Blackout25's Avatar
Blackout25
Its definitely a torx, T45, just had mine off not long ago. I had to get a longer T45 key and a cheater pipe. Broke my T-handle, and the hole was too narrow to fit normal ratchet bit down. Only thing i found in town was longer torx keys instead of longer bits. I ran out of PB blaster, but I wouldve tried to spray some behind it first. Sometimes helps loosen up factory loctite.
---Had I stripped it, I would have but the bullet and just cut the bracket down with sawzall, so I could get my screw-out/extractor on it. I eventually want to replacement the rear pegs for footboards so wouldnt have been too big a loss.
Good luck
Old Sep 24, 2024 | 02:45 PM
Uncle G.'s Avatar
Uncle G.
I confess that after reading the various horror stories on this forum about removing the rear pegs, I had the dealer do mine while I had the bike in for a minor repair.
For some reason the MoCo decided to drown every fastener in Loctite.
Old Sep 24, 2024 | 09:17 PM
Blackout25's Avatar
Blackout25
+1. I wish I would've took a pic, almost the whole bolt has loctite on it when it came out. Few threads, maybe half on the heavy side at most. This was like they dipped the thing and wiped off the head lol
Old Sep 25, 2024 | 06:05 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I was rather gobsmacked by the amount of loctite on my saddlebag screws. It was indeed like they were dipped.
Old Sep 25, 2024 | 06:47 AM
Durham man's Avatar
Durham man
I have done a lot of unbolting on my bike. Pegs and peg brackets were not bad. The kickstand bolts were the toughest by far.
Old Sep 26, 2024 | 09:42 AM
Shiv's Avatar
Shiv
Stage III
Got it fixed. Once I chose the right tool and positioned it straight into the bolt everything worked out. Thanks for your help.
Shiv
Stephen7
Jul 27, 2024 02:12 PM
Smither's
Jun 6, 2012 05:53 PM
vl1500
Nov 1, 2009 07:57 AM
Original Junior
Dec 7, 2006 05:37 PM
waffler
Sep 10, 2006 08:54 PM
