2018+ Softail Models Breakout
M8 air cleaner
Old Sep 17, 2024 | 01:00 PM
Mr.Rabies's Avatar
Mr.Rabies
Default M8 air cleaner
Anyone know of what would possibly be a lightweight air cleaner? I have the screamin eagle stg1 its ok however I cant easily modify the "direction of blowby".
any suggestions?
Old Sep 17, 2024 | 02:08 PM
evildiesel's Avatar
evildiesel
get rid of the head breather "blow by" entirely
https://www.hdforums.com/forum/2018-...-possible.html
Old Sep 18, 2024 | 05:41 AM
ACE_Moto88's Avatar
ACE_Moto88
any suggestions?
Which air cleaner do you have? If it's the OEM "Ventilator" style, oval shaped, you can do what many others have done as well as myself and drill two holes in the backing plate and route some 1/4" ID tubing from the breather bolts through the backside of the plate and connect to a tee and vent to atmosphere underneath the bike. Free and cheap mod to stop the oily vapours from getting routed back into the intake to be burned and causing unnecessary carbon buildup on top of the pistons.
Old Sep 18, 2024 | 05:54 AM
ricklee4570's Avatar
ricklee4570
Great advice. Easy to do and cheap. Very effective!
Old Sep 18, 2024 | 07:42 AM
Mr.Rabies's Avatar
Mr.Rabies
Originally Posted by evildiesel
get rid of the head breather "blow l
that requires new heads
Old Sep 18, 2024 | 08:35 AM
ACE_Moto88's Avatar
ACE_Moto88
Here's a video of basically the setup I created. I ended up drilling two holes and making the tee connection outside of the intake but it's the same concept.
Old Sep 18, 2024 | 09:27 AM
Mr.Rabies's Avatar
Mr.Rabies
i dont have the oem intake. its the stg1 screaminchikn deal
Old Sep 18, 2024 | 11:01 AM
ricklee4570
Thanks for the video, I ran mine out the back of the air filter plate requiring two holes. The tee fitting is behind the air cleaner. Now that I see your set up, I wish I would have gone that route. I like the way you did yours much better.
I also have mine just routed below the bike, no catch can. Are you getting any oil in your catch can?
Old Sep 18, 2024 | 12:56 PM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
The 114 Oval on the non FXLRS/FXDR bikes is the screamin eagle Ventilator. It's just a different kit with all the same parts, except an SE badge, and K&N Filter.
Old Sep 18, 2024 | 01:27 PM
Mr.Rabies's Avatar
Mr.Rabies
this is what i have
https://www.wisconsinharley.com/harl.../?sku=29400355
was told its stg1 or whatever #. either way the filter blocks half of the evap hole. il have to be creative or make my own air cleaner
