2018+ Softail Models Breakout
Shift linkage
Old Sep 28, 2025 | 04:08 PM
drbf's Avatar
drbf
Default Shift linkage
Does anyone know if the forward control shift linkage is adjustable on the 2025 Street Bob?
Thanks
Old Sep 28, 2025 | 04:39 PM
Ohio HD's Avatar
Ohio HD
Yes it shows as adjustable. But you should be able to see that, as it has lock nuts on each end of the rod, and exposed threads for adjustment.
Old Sep 29, 2025 | 10:39 AM
drbf's Avatar
drbf
Is it adjustable without removing from the bike?
Old Sep 29, 2025 | 11:23 AM
Jackie Paper's Avatar
Jackie Paper
Signed on to hear about a 25. Never seen a Harley that you didn't have to remove one end since both fittings have right hand threads.
Metrics have a right hand and a left hand thread on their shift rod.
Threads however are for minor changes. Index the lever spline for big changes. And be sure to tighten properly to service manual spec and proper loctite on the lever fastener.
Seen numerous threads on here with the spline striped. And the reason is not tighten it correctly.
Old Sep 29, 2025 | 12:15 PM
Ohio HD's Avatar
Ohio HD
You loosen both lock nuts, then remove it from the foot shifter end, then turn both ends outward or inward the same number of turns. Hand tighten the two nuts, put it back on the foot shift end, then tighten the two lock nuts snug.
There are some aftermarket manufacturers that have a righthand thread on one end and a lefthand thread on the other. In those cases you just loosen the nuts and turn the rod to lengthen or shorten.
I have shift linkages on my bikes from Thrashen Supply, they have left and right threads on their linkages.
https://www.thrashinsupply.com/produ...e4760235&_ss=r
SOCALHD
Screamin Eagle CVO Models
Oct 15, 2014 10:46 AM
bobbleheadray
Mar 27, 2012 03:32 PM
Mr. Wannabe
Jan 1, 2012 11:08 AM
Radioman_cut
Apr 20, 2011 07:53 PM
vegashd
Apr 28, 2006 04:42 PM
