2018+ Softail Models Breakout
Seats
Old Feb 24, 2026 | 10:26 AM
Big Al 59's Avatar
Big Al 59
Nice looking seat, can you tell us if this one raise you and push you backwards, what I need, I am 5"11 with 34 inseam...
Sorry that you are in so bad weather, here in south west of France, we had a big storm last week and lot of rain, now it's better, I mowed the lawn for the first time
Old Feb 25, 2026 | 08:23 AM
MesquiteFLD's Avatar
MesquiteFLD
Yesterday was my first ride with the Corbin. It is VERY comfortable. It moves the rider back 1.5 inches, it seems just a tad higher than stock.
Friday the Krause pullback plate will go on. That will make the bike fit me very well. I am 6’ with. 35” inseam.
Old Feb 25, 2026 | 08:36 AM
MesquiteFLD
84F and sunny here this coming weekend. I know what my wife and I will be doing. Ride baby, ride!
Old Feb 25, 2026 | 01:28 PM
Big Al 59's Avatar
Big Al 59
Good to know as I have nearly the same stature
With the Kraus plate you will have to replace the wires and cables ?
Old Feb 25, 2026 | 05:05 PM
MesquiteFLD
Installation is being done Friday. I had a medical procedure on my hands and can not turn a wrench right now. I am having Zion HD do the install.
From what I hear there is no need to add longer cables or wiring. One guy said he had to pull the tank to pull some slack out of the wiring, other said no need to pull the tank.
Old Feb 26, 2026 | 01:31 AM
Big Al 59's Avatar
Big Al 59
Thanks for your reply, please keep us updated when it's done.
I hope you recover quickly.
Old Feb 26, 2026 | 07:10 AM
$tonecold's Avatar
$tonecold
There's a lot of extra wire on a '25 LRS-ST. I went with 6" pull back risers, no problem.
Old Feb 26, 2026 | 09:25 AM
Big Al 59's Avatar
Big Al 59
Hope it's the same on the 25 LRS
Old Feb 27, 2026 | 05:29 AM
Bikes and Boards's Avatar
Bikes and Boards
In 22, the LRS did not have any slack, but my bike builder said the LRS-ST did. He did the same riser on my LRS and another customer's ST. My job needed new brake/clutch lines, the other customer's ST did not. Hope that has changed.
Old Feb 27, 2026 | 08:52 AM
$tonecold's Avatar
$tonecold
On the 2025, between the S & ST, handlebars are the same, risers are the same, wiring in the handlebars is the same, upper front brake line is the same. The brake line was maxed when I installed the higher bars, any more and it wouldn't make it. Upper clutch cables are not the same, but the clutch cable was the one thing I had to extend, and I didn't have to do that until I installed the handlebars from a Road Glide ST. They have about a 6" rise. So in all I increased the rise of my bars about 6". I used a Fat Baggers extension on the clutch cable, it does get rid of the plastic case, but the plastic part that breaks is still used. There are cables that will extend it from Harley. I think the Fat Boy cable is one. Eventually I will go with a Magnum old style adjustment cable, they just don't offer it yet, at least they didn't the last time I checked. The only other thing that is pretty much maxed out is the speedometer wire. I don't think I could go with taller risers without extending it.
So you should be able to do significant changes to your bars without having wiring problems, but there are a few things that will need to be changed.
