2024+ Center-Cooled Touring Models 2023.5+ CVO and 2024+ Road Glide/Street Glide/Street Glide Ultra Center-Cooled Gen 2 M8 Touring models
Error Code
Old Mar 1, 2025 | 07:26 PM
srms411's Avatar
srms411
Default Error Code
Finally got a great day to ride my 2024 Street Glide. All was going well until I got the error code DTC P06930. I did a quick search and it says it is related to the Coolant Fan. After checking the Cooling fan relay, visually inspection of the cooling fan area and the fuses. I could not find any issues. After numerous attempts to reset the code and restarting. The bike still persists in generating the error code. I also observed the Coolant Temp after riding to be in the normal range.
Is anyone else experienced this. Is it a known issue and what was the remedy.
Thanks
Old Mar 1, 2025 | 07:34 PM
mjwebb's Avatar
mjwebb
Thanks
why would you have reset the code instead of consulting with dealership for warranty? Either way it returned so take it in
Old Mar 1, 2025 | 07:51 PM
rideonva's Avatar
rideonva
Did you recently upgrade your IFCU software, member here (or on the other forum, don’t remember) had similar problem after upgrade. Check that you have CoolFlow fan set to off. If I remember correctly, this DTC is set when there’s no CoolFlow installed but in IFCU it’s set to something other than off; if it’s already off ask dealer to make sure it’s disabled in BCM.
ETA: it’s not Coolant fan, it’s CoolFlow aka chassis fan.
Old Mar 1, 2025 | 08:34 PM
srms411's Avatar
srms411
Thank you all for your responses. II’ll post how I make out.
Old Mar 1, 2025 | 09:22 PM
srms411's Avatar
srms411
Rideonva, Thank you very much for your help and information. Sure enough the “Coolflow fan” was set to auto and also activated in the system menu. After disabling it in both settings, I have been able to clear the code and the dreaded “yellow triangle” has disappeared. Thanks again and I will pass it on to others who might experience what i did.
Old Mar 1, 2025 | 11:46 PM
mjwebb's Avatar
mjwebb
I've yet to get a clear understanding from Service or elsewhere on what all triggers that damn thing..what I have been able to determine is that it comes on occassionally / randomly, and only when the bike has sat overnight and turned on first time 'cold' but after a ride of any length or duration and shut off, it never displays again when started up for the rest of the day..it never trips a code either..chalking it up to early adopter bugs glitches with IFCU / Skyline OS I guess
Maz27
Electrical/Lighting/Alarm
18
Sep 14, 2024 08:44 PM
FLSTFI Dave
Pan America
46
Oct 31, 2022 05:20 PM
ntg433
Milwaukee Eight (M8)
Aug 29, 2017 09:29 PM
hover
Apr 20, 2013 10:14 PM
BlockHead96
Engine Mechanical Topics
Oct 23, 2008 12:48 AM
