2024+ Center-Cooled Touring Models 2023.5+ CVO and 2024+ Road Glide/Street Glide/Street Glide Ultra Center-Cooled Gen 2 M8 Touring models
Nosecone
Old Jun 17, 2025 | 05:09 PM
Max Headflow's Avatar
Max Headflow
Question Nosecone
I noticed that the new M8s have a new cam cover. Any one know why?
Is it primarily for the VVT motors so they know the cam position?
Old Jun 17, 2025 | 08:21 PM
rideonva's Avatar
rideonva
It is for VVT, but for the rest of the models I guess it would be to just produce one size fits all.
Old Jun 18, 2025 | 05:44 AM
jake24lt's Avatar
jake24lt
If you look closely, there is wires that go into the cover for a cam sensor. On the end of the cam now, is like a "reluctor" or locating wheel. that the sensor must use to locate cam position. The interesting thing is, when you remove that wheel from the cam, there is no indexing it to where i was. Effectively, you just bolt back on the cam any which way and it works. The regular CC bikes have these
Old Jun 18, 2025 | 10:12 AM
Max Headflow
snip
Thanks for the pic. I dug up the wiring diagram and it appears that all the M8s now use the cam sensor.. I suspect it's mainly because the SE bike with VVT might use the same Core ECM.. It seems to me to be unnecessary tho without VVT.. I'd expect that the position is unimportant as It can be determined at startup. Not sure I'd call the rotor a "reluctor" as the sensor is hall effect.. (got 3 wires)
On the non VVT bike the CMP is still there but the VVT control is not..
Old Jun 18, 2025 | 10:48 AM
jake24lt's Avatar
jake24lt
Yea I used that terminology along with "locator wheel" as I didn't know what to call it. I just know theoretically how it works. I guess one could disconnect it and see if the computer throws a code?
Hannibal Smith
Shovelhead
Nov 13, 2018 09:25 PM
raysoftail
Engine Mechanical Topics
Feb 22, 2017 11:54 AM
dano13208
Mar 17, 2014 05:42 PM
RidemyEVO
EVO
Feb 8, 2012 09:39 PM
1931jamesw
Nov 19, 2010 04:33 PM
