I was staying away from the SAS because you have to drop the system to change the Trans fluid, but now it sounds like you need to do that anyway. Nobody has said that before in the other air ride threads.
I think I like the integrated system myself. Eliminating the hoses seems to be a good idea.
the sas is very simple to install. have had it for 1 1/2 years. had a problem twice. one i broke the toggle switch. the other my compressor wasn't pumping enough air into the system because i didn't run the external breather that has a filter on it and i got water on the inside of the unit. talked to custom cycle, they took the unit back and 3 days later they sent me my unit back. just remember no matter what air ride you go with. thier will eventually be problems so save your stock shocks so you don't have to buy new ones if you have any problems.
Well, I'm leaning pretty heavily towards the SAS... looks like a great solution. If I'm going to spend a grand for a major accessory for my $20k+ bike, might as well spend another $500 or so for the best solution.
As far as dropping the SAS, or any other replacement, to access the tranny plug, it sounds like the SAS is easy to get out of the way as infrequently as I'd have to do it.
I still have to do more research on the other suggestions, as I don't think I have enough information to make the final decision. Thanks for the tips, and keep the input coming!
Thought I would through another name in the mix! Arnott http://www.arnottairride.com/product...sp?groupId=137
Bilstein shocks and Goodyear air bags. Hard to beat not a lifetime warranty but here is their warranty:
Warranty Information:
Take the Arnott Challange today!
If you are not 100% satisfied with your new air ride system, we will refund 100% of your purchase price, if returned within the first 30 days. The system also comes complete with a full 5 Year Warranty.
Have this setup on my Night Train after I did the Heartland 250 Kit, the SAS rides better than stock even 2up riding. Very comfortable and predictable around turns.
