Air Suspensions All you Air Ride Suspension Owners can discuss your Rides here
Where are you mounting the toggle switches?
Old Nov 9, 2010 | 07:43 PM
mimo's Avatar
mimo
Not toggle but pressure on/off button (like the one used in our OEM odometers)
You can see it on the left grip right on the controls housing screw:
Mimo.
Old Nov 9, 2010 | 08:50 PM
nikonf8's Avatar
nikonf8
Default switch
my led switch is on the coil cover when the samsons were installed it had to be moved from the bottom of the cover to the top
Old Nov 9, 2010 | 09:25 PM
j33ptj's Avatar
j33ptj
I installed the aux switch system for additinal switches for my air ride. Didn't use the switches from HD but the toggle switches on a blanking part, but the housing fits nicely
RJ
Old Nov 9, 2010 | 11:08 PM
Morris9982's Avatar
Morris9982
I used HD part 70248-02B ($34.95) for the switch housing and 71718-02 ($13.95) for a switch on my bike. They match the other things on the handle bars and are easy to use when riding. The housing holds three switches.
Old Nov 10, 2010 | 07:45 AM
IronAss's Avatar
IronAss
I bought one of the old school spare spark plug holders and drilled a hole in the end of it and put the switch there. They were made to mount on the frame downtubes but the newer bikes tubes are too big so I put it up on the handlebars. I use it for my passing lamps and keep a spare set of plugs in it as well.
Old Nov 10, 2010 | 09:24 AM
tk353's Avatar
tk353
i have my heater control and garage door opener on the left side of the console. if the lights are to be on when parked why not connect to the acc side of the power on the ignition switch?
Attached Thumbnails Where are you mounting the toggle switches?-heater-control.jpg
Old Nov 10, 2010 | 01:34 PM
Schaub85's Avatar
Schaub85
My air switches are on top of the coil cover
Rusty Axle
Shovelhead
Jan 20, 2019 09:02 AM
AHH
Sep 23, 2013 01:13 PM
agiffey
Aug 10, 2012 01:31 PM
Cruzer Dude
Mar 23, 2008 05:09 PM
outdoorgirl57
Feb 19, 2007 02:17 PM
