Air Suspensions All you Air Ride Suspension Owners can discuss your Rides here
Shotgun shock install
Old Aug 4, 2011 | 03:20 PM
Sailrider 1's Avatar
Sailrider 1
Default Shotgun shock install
After reading the reviews here on the forums, I am considering installing the shotgun shock on my 2010 FatBoy Lo. I have a lift table' but for those who have installed what did you use to lift the bike so you could work under the frame ? Most of the jacks I have seen go right under the frame right where the shotgun shock is installed or am I mistaken ?
Pics of where you installed the control switches would be nice also.
Old Aug 4, 2011 | 03:41 PM
Sofmech's Avatar
Sofmech
I used a lift I bought from Harbor Freight. It wasn't a stand but two "forks" to lift the bike. Just had to get it in the right position in order to clear the shocks. I also used a small automotive jack under the rear tire to be able to move the suspension. Fairly easy install, just a tight spot.
Old Aug 4, 2011 | 03:55 PM
jneubig's Avatar
jneubig
Pretty much the same for me as above post. I moved my jack (J&S Jack) a little more forward than I normally do, but it worked out just fine. I mounted my switches using the horn bolt just above the horn "cowbell". Great shock by the way. You will not be disappointed.
Old Aug 4, 2011 | 06:00 PM
ghostrider69's Avatar
ghostrider69
I haven't installed a Shotgun shock but I have used my HF High Lift jack to remove my stock shocks and install lowering bolts. The arms fit behind and in front of the shocks and will lift the bike plenty high to perform any work you may need to do.
http://www.harborfreight.com/high-po...ift-99887.html
Old Aug 4, 2011 | 06:31 PM
Blk and Chrome's Avatar
Blk and Chrome
just used my cycle jack its all about the postion. Pretty easy job, you will love them. The swtiches are above the cowbell
Old Aug 4, 2011 | 06:34 PM
PanHeadRich's Avatar
PanHeadRich
In regard to the Harbor Freight left they're talking about, this is how I positioned the forks under my bike to drop the shocks.
Old Aug 4, 2011 | 09:53 PM
Scheers44's Avatar
Scheers44
We used a full size bike lift so it made life very easy!! Switches are mounted behind cowbell where the brackets designed to go. May end up in dash panel this winter who knows. You'll love em! Call JD and order em now! LoL
Old Aug 4, 2011 | 11:16 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
The isntall is very easy. I have the smae lift as in the above pictures. Simple to postion it coreectly and teh isntall takes about an hour to two if you are a beginner.
Drew
Old Aug 5, 2011 | 12:34 AM
Hawaii-Five-Jo's Avatar
Hawaii-Five-Jo
Used a regular motorcycle jack and a 4x4 block for the rear tire. Switches mounted on dash in front of speedo.
Old Aug 5, 2011 | 02:32 AM
j33ptj's Avatar
j33ptj
I mounted the switches on the handle bar...
Attached Thumbnails Shotgun shock install-shotgun-switches-01.jpg   Shotgun shock install-shotgun-switches-02.jpg
