Was given questionable info
Old Sep 21, 2014 | 02:04 AM
ridedaddy's Avatar
ridedaddy
Default Was given questionable info
I had called biketronics a day or so ago due to a small issue im having with my 6x9s and as always biketronics stepped up and have no problem standing behind there products. On a side note I was having a conversation with them about the output of a 2180 @ a 2ohm load. Mainly becouse I have the chance to pick one up fairly cheap, even though I've been holding out for a 4180 I was thinking this may be an improvement over my 4.520d for now. So to get to the point... To my suprise robin at biketronics claims that at a 2ohm load the 2180 will double its output? Claiming each of my four speakers will still see 180w. Meaning the amp will put out 360w per channel at 2 ohms for a total of 720w? Now I'm no guru or anything but typically this is not how a 4 ohm to 2 ohm relationship works. I know I have read several times and been apart of many conversations on here where some have stated that bt has claimed around 230w per channel at 2ohms. I'm not sure if I just recieved bad info and maybe should have saved that question for bill or if anyone here has any info that may help.
Old Sep 21, 2014 | 02:05 PM
Pioneer74's Avatar
Pioneer74
I was told by Bill on the phone that the 2180 and 4180 produce about 230 watts RMS per channel with a 2 ohm load. This was last year around Christmas.
Old Sep 21, 2014 | 09:50 PM
AAWAV's Avatar
AAWAV
Theoretical it should double. Problem is that with lower impedance load the efficiency of an amp goes down.
I only read about the 230w as pioneer74 mentions below.
Old Sep 21, 2014 | 11:31 PM
ridedaddy's Avatar
ridedaddy
Hmmm, well either way I'm sure a 2180 would be an improvement over the ss 4.520d. Wouldn't you agree?
Old Sep 22, 2014 | 05:15 AM
Pioneer74's Avatar
Pioneer74
Absolutely. You're comparing a Mustang to a Yugo.
Old Sep 22, 2014 | 08:00 AM
Oilsmoke's Avatar
Oilsmoke
LOL I spit coffee on my laptop thx
Old Sep 22, 2014 | 09:21 AM
austinslider's Avatar
austinslider
I don't think my amp is a Yugo, maybe more like a Ford Fungus...
Old Sep 22, 2014 | 09:46 AM
Pioneer74's Avatar
Pioneer74
There's nothing wrong with a Yugo. Basic, inexpensive transportation that will get you where you need to go. Just doesn't get you there with speed or style.
Old Sep 22, 2014 | 04:47 PM
Geezer glider's Avatar
Geezer glider
I don't know the output of either the 2180 or 4180. All I know is that the 4180 and 6.5 and 7.1 speakers I bought from BT is clear and as loud as I care to crank it. The warranty is a nice extra.
Lancemchn
Aug 4, 2018 11:32 PM
InthewindMN
Audio Systems
21
Jul 16, 2017 05:35 PM
roussfam
Audio Systems
14
Jul 7, 2016 06:54 AM
just plain john
Audio Systems
Aug 18, 2015 07:33 PM
FXDXTSport
Nov 19, 2014 03:07 AM
