Adding rear speakers?
Old Nov 22, 2014 | 11:54 AM
06DEUCE's Avatar
06DEUCE
Default Adding rear speakers?
I have a 05 EG with stock head unit. I'm upgrading the front speakers,adding an amp and rear speakers in the lids. My ? Is how do I add rear speakers with no rear speaker output from the head unit?
Thanks
Old Nov 22, 2014 | 05:11 PM
06DEUCE's Avatar
06DEUCE
I'm guessing I need to splice the front speakers into the input on the amp for the rear?
Also now that I'm getting things hooked up I notice my handle bar control that changes the modes between radio,cd,aux has stopped working? Volume side works fine? Any ideas?
Old Nov 23, 2014 | 07:18 AM
UltraNutZ's Avatar
UltraNutZ
your stock head unit is already equipped with active rear outputs on the 35 pin connector. You have a couple of options to get to them
1. build your own connector to allow connectivity to pins 1,2,24,25
2. buy a connector like this.
3. get the pins you need for the connector from HD. Solder and shrink warp the pins and plug them into connector on the back of the radio
if you want the fader to work, you'll need to have that flashed by HD. takes 5 minutes and they charge you about $40.
Old Nov 23, 2014 | 11:45 AM
06DEUCE's Avatar
06DEUCE
Will that connector work on my 05? Says 06 and up.
Old Nov 24, 2014 | 09:46 AM
pp6000v2's Avatar
pp6000v2
You have the radiosound head unit maybe? It's been a while and I don't remember if the Non-CB headunits on those had the 2nd big harness connector on the back. Assuming it does, the Ultra connector on the back of it is a 23-pin connector, not the 35-pin that the HK head units have. Either way, it's pretty easy to fab up your own harness connector to do this:
  • (4) 72381-98 socket pins $2
  • (1) 72383-98GY 23-pin connector housing $20
Pins you need (the connector has labels on the ends of rows so you can figure out which is which):
3: left -
4: right -
10: left +
11: right +
Old Nov 25, 2014 | 04:14 PM
06DEUCE's Avatar
06DEUCE
Upon further review. I think my amp (pbr300x4) can take the two channel stereo and turn it into a four speaker output.
Old Nov 25, 2014 | 04:16 PM
UltraNutZ's Avatar
UltraNutZ
it can.. just won't having fading abilities
uwiik
Audio Systems
Aug 26, 2018 08:49 PM
3/4 life crisis
Jun 19, 2016 07:26 PM
TheLazyC
Audio Systems
May 6, 2013 06:00 PM
rrcrum
Audio Systems
13
Mar 6, 2013 09:16 PM
John Schleifer
Aug 19, 2010 03:25 PM
