Nope, I was wrong. I am actually running the ARC audio 125.2 amp. I bought both amps before I installed it and decided to go with the Arc audio one instead. One of the issues I am having is sometimes when I turn the bike on, I get no sound. If I turn the bike off and then back on it works fine. The other one I have is it doesn't sound as loud as I think it should and when I turn it up sometimes it goes up about half or three quarters loud and then actually gets softer. Any thoughts?
Are you saying you have a BT2180 laying around that you are not using?
No I got the Arc audio amp from a friend and bot the Biketronics one of the internetand then sold the biketronics amp on ebay to help pay for the Rokkers.
I would like a system that comes on every time I turn it on and sounds loud and great. I am thinking maybe I should just upgrade to the new Rokkers and get the Rockford Fosgate PBR Amp. Thoughts
Sounds like a plan. Just not sure of the capability of the Rokkers to handle the PBR300X2. Might want to give JM John a hollar. I've had quite of few of those amps in my possession and the birth sheet @ 2 ohms is anywhere from 175 to 191 RMS. Should be okay if you keep the gains low but I've always been foggy on the specs for the JM speakers and I've had a couple sets a few years back. I do know the new Rokkers sound much better than the one's I had.
Just talked to John, he recommended getting the new speakers first and checking the connections and settings on the ARC amp. He said that amp should work good with the speakers, so I guess that is what I am going to start with. Luckily I have a couple of months to play with it before I will be able to ride again. I will keep you posted once I get stuff going. Happy Holidays!!!!!
