Biketronics for 2014 Street Glide
Old Jan 16, 2015 | 01:18 AM
MKennedy616's Avatar
MKennedy616
Ok, after reading a bit more of the 2014 sticky... I have this question...
What is better with the biketronics setup... Getting the flash done or adding the 'magic box'... What are people's experiences with both?
Thanks!
Old Jan 16, 2015 | 02:08 AM
Aversocki's Avatar
Aversocki
I'm in between this setup and a level 4 kit with the focal speakers from Soundz customz myself. Can't decide, gonna do the speakers in March most likely.
Old Jan 16, 2015 | 03:57 AM
Gannicus's Avatar
Gannicus
Thanks!
I've not had the opportunity to install a system on a 14 yet but NUTZ always recommended getting the 8 speaker flash vs. the magic box. Very respected and trusted individual in regard to audio on a bike. (and also a good friend)
Old Jan 16, 2015 | 04:57 PM
HD_Doobie's Avatar
HD_Doobie
Thanks!
My suggestion would be to talk to your dealer. See if they have flashed any bikes yet. Do they know what they are doing with the digi-tech. Will they allow you to come into the shop and see and hear what's going on. Will they be patient with you and allow you to try a couple different flashes to see what's best. Everyone says to do the 8 speaker no amp flash, but see if they will experiment a bit. Finally, what is the cost.
If they don't seem like they will work with you, either go else where, or run the magic box.
FYI... I am using the magic box. Sounds fine to me, but I am very curious as to what it would sound like with the flash as maybe I am missing out on some sound quality...
Old Jan 18, 2015 | 12:49 PM
MKennedy616
Thanks Gannicus! I read a lot of input from Nutz... It's a shame he's gone now... He is incredibly knowledgable... I've just got to hope that my dealers maintenance department knows what their doing with the flash!
Old Jan 28, 2015 | 10:04 PM
MKennedy616
Ok, so I've got the speakers and amp all installed... Just about to run the power under the tank. I have a question...
Should I loctite all of the speaker and bracket screws? I didn't think about it when doing the RH side. Then, I put loctite on all of the LH screws... They just seem to be really short, but they seem pretty snug as well... I would just hate to have any come loose down the road.
Has anybody had any issues with BT brackets and hardware coming loose?
Old Jan 28, 2015 | 10:17 PM
dirtracin23's Avatar
dirtracin23
If it's a regular threaded bolt or machine screw, it gets blue loctite on my machine. Sheet metal screw or anything going into plastick then no.
Old Jan 29, 2015 | 06:18 AM
zeke383's Avatar
zeke383
Agreed
Old Jan 29, 2015 | 06:50 AM
Gannicus's Avatar
Gannicus
All the BT kits are solid kits and I can't recall any hardware ever coming loose but as dirtracin said blue Loctite is always good for machine screws and threaded bolts. Nothing wrong with a little extra insurance!
Old Jan 29, 2015 | 08:42 AM
MKennedy616
Ok, cool. Thank you guys! I'll go back and redo the RH speaker and bracket.
And one more loctite question... I know it should be above 50*F to install the loctite, but I don't have heat in my work area and it's generally in the 30-40's when I'm working in there... Is it still going to cure, just take longer than the normal 24 hours?
Sorry, I know that's not really an "audio" question... Just making sure my logic makes sense! And yes, I know true logic says I should get a heater in my work space!
