Alpine KTP-445U power question
Old Jan 21, 2015 | 10:18 PM
sgr60's Avatar
sgr60
Default Alpine KTP-445U power question
Looking to do a little upgrade to my audio system. Not going crazy, just going to put in an Alpine KPT-445U amp and the Infinity Kappa 6.5" speakers. From what I've read, it should be more than enough for what I'm looking to do.
My question - the listing for the amp on Amazon says that it "Runs off same power circuit as receiver". While it's surely less involved not having to run that power wire, does the amp really not require it? It seems really hard to believe, so I was wondering what others have done?
Old Jan 22, 2015 | 11:47 AM
Gannicus's Avatar
Gannicus
Always better to run the power wire off the battery with an Inline fuse.
Old Jan 22, 2015 | 06:40 PM
HD_Doobie's Avatar
HD_Doobie
Any certain reason you want that amp?
Old Jan 22, 2015 | 07:23 PM
sgr60's Avatar
sgr60
Well, not really. It was mostly because I saw the note about not having to run power which seemed convenient. That said, if I do have to run power, my alternate was the RF300x2 - which looks like a nice unit.
Old Jan 22, 2015 | 07:25 PM
Juice's Avatar
Juice
Not a bad little amp powers my fairing and CVO lids, polks all around just fine. fits nicely on top of the head unit and as Gannicus said run a power wire from the battery.
Old Jan 22, 2015 | 07:34 PM
HD_Doobie's Avatar
HD_Doobie
Running power and ground to the battery is best, and it's actually quite easy...four bolts on the tank, quick disconnect on the fuel line, one screw and one bolt for the dash, one quick disconnect for the fuel pump and the tank is off.
Old Jan 23, 2015 | 11:01 PM
sgr60's Avatar
sgr60
I guess it might be worth going with the RF amp then - sounds like a better option if I'm going to be running the power wire from the battery...
Budda109
Audio Systems
Jan 15, 2019 06:56 PM
dynabobstreet
Aug 25, 2015 07:18 PM
awright5335
Audio Systems
Oct 6, 2014 09:55 AM
shortride
Aug 22, 2010 04:58 PM
INZANE
Aug 27, 2009 08:35 PM
