It seems there are more than one. Doing a little research I found 250w 500w and 1000w all 2 channel. I would really like the BT4180 or even the 2180 but not enough cash flow for both the BT 7p1's and the BT amp so Im needed options. On a side note I'm also replacing the HU with a Kenwood x798.
There is only 1 CV B2 amp, you must be looking at all of the B series amps but if you read there is only 1 amp numbered B2 that is the amp you would want.
Also most class D amps will make you lose some or all of the radio stations due to the switching design of the amp itself.
Just go with the BT2180 amp and be done with it.
I hear you Card.... But the man said his cash flow doesn't permit the 2180 right now. The Cerwin Vega B2 will fit his budget.
